Pedal to the floor and no go!
Old Mar 8, 2006 | 05:10 PM
weppskilla's Avatar
Default Pedal to the floor and no go!
91' DX dpfi to mpfi conversion obdo (for now) D15B Vtec. only a map code going off, but when I drive the car it is floored to the ground and the car is going like 2mph! WTF is going on? the car is timed right and the distributor is at zero.
The car also dies when I take off. The map code is going off because of the vac. lines. when I had a si motor in there (a d16a6) all was fine. Did I have3 to switch any wires when I swapped the d15b Vtec?
Old Mar 8, 2006 | 05:27 PM
jdm91CrxSi's Avatar
Default Re: Pedal to the floor and no go! (weppskilla)
no **** man, you didn't even get a vtec cylenoid? you went from a non-vtec to vtec you got to have diffrent wiring, injectors, ecu and more
Old Mar 8, 2006 | 07:28 PM
weppskilla's Avatar
Default Re: Pedal to the floor and no go! (jdm91CrxSi)
No ****!, but I can run a obdo ecu and distributor with a d15b VTEC! and the I do have a VTEC hooked up thank you! My question is all of the wiring the same besides VTEC?
Old Mar 8, 2006 | 08:25 PM
Ahks's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm91CrxSi &raquo;</TD></TR><TR><TD CLASS="quote">no **** man, you didn't even get a vtec cylenoid? you went from a non-vtec to vtec you got to have diffrent wiring, injectors, ecu and more</TD></TR></TABLE>
i love it when a post is almost totally useless
try these link weppskilla
http://www.gutterslide.com/fou....html
http://www.pgmfi.org/twiki/bin...-OBD1
or
https://honda-tech.com/zero...age=1
http://diy.prostreetonline.com...id=40
https://honda-tech.com/zerothread?id=1171263
http://www.hondaswap.com/forum...29360
and for the lazy
http://www.rywire.com/store/index.php
those are some of the resources i'm using for a obd1 conversion... alot of them include mpfi info gl
Old Mar 9, 2006 | 08:45 AM
weppskilla's Avatar
Default Re: Pedal to the floor and no go! (Ahks)
Thanks Ahks! I got the p28 ecu, jumper harness, and the rywire distributor harness as well, I'm just lazy and also wanted to compare the obdo performance to the obd1 for myself. But like I said pedal to the floor and it doesn't go! Guess I will have to do the obd1 conversion swap in order for it to run well.
Old Mar 9, 2006 | 09:16 AM
citystar707's Avatar
Have you checked your throttle cable?
Old Mar 9, 2006 | 09:23 AM
weppskilla's Avatar
Default Re: Pedal to the floor and no go! (citystar707)
Yeah, I still have the old DX one, I have not upgraded to the si one yet. But yeah I adjusted it and when I am in neutral I can rev the **** out of it!, but when I put it in gear a take off it will go like 2 mph floored to the ground!
Old Mar 9, 2006 | 11:24 AM
highrev1987's Avatar
hold on are you running the full obd1 setup or a obd0/obd1 combo? because the tps sensor and stuff like that require slight rewiring.
check this site it should have everything you need.
http://www.boomslang.us/obd0_1.pdf
Old Mar 9, 2006 | 11:43 AM
technine's Avatar
Map code = something wrong with map sensor and/or connections. Check to see if you have the right hose connected to the sensor and make sure your vacuum hoses are connected to the right spots.
Had the same thing happen to me and then checked my vacuum diagram and sure enough the power was there after I re-routed some hoses.
Old Mar 10, 2006 | 10:15 AM
weppskilla's Avatar
Default Re: Pedal to the floor and no go! (technine)
I'll do that tech, and high! I don't think my vacum hoses are right, Plus I got to get the right map sensor (just orderd it, the one on the throttle body) so I will check all those things at once. Also I am running all obdo for now but, I have all of my obd1 stuff here now. I will keep you guys posted.
Old Mar 11, 2006 | 07:27 PM
weppskilla's Avatar
Old Mar 11, 2006 | 08:13 PM
eltigre's Avatar
make sure ur pedal is even connected
Old Mar 11, 2006 | 08:26 PM
Default Re: Pedal to the floor and no go! (eltigre)
thats not very helpful
Old Mar 13, 2006 | 12:27 PM
technine's Avatar
I forgot which vac lines go where, but I think it was the vac line coming off the throttle body to the MAP and the rest is a haze for me. Anyone on here have the correct diagram?
Old Mar 13, 2006 | 12:38 PM
technine's Avatar
Old Mar 15, 2006 | 08:00 AM
weppskilla's Avatar
Thanks but I need the one for the D15b vtec or D16z6. The one where the MAP sensor is on the throttle Body.
Old Mar 15, 2006 | 08:10 AM
EF9ZC's Avatar
in order to run a d16z6 correctly do you have to have the map sensor on the throttle body or can you just use the one on firewall/
nkcalvert09
Jun 11, 2011 10:43 PM
slammed_92_accord
Apr 27, 2006 07:46 PM
nitrousfedef9
11
Oct 5, 2005 09:13 AM
wfo
Feb 25, 2005 02:21 PM
DOHC_VTEC69
Jan 20, 2005 08:24 PM
