2000 SI CEL
Old Mar 8, 2006 | 01:26 PM
Rocket Man's Avatar
Default 2000 SI CEL
Hey what's up? My friend has a 2000 SI civic i've searched on the forums for a problem similar but didn't see one. First a little info on the car then ill tell you the problem. First all if i had went with him as planned i would of told him not to get the car. It has 50k miles on it and it looks and sounds like it's been run thru hell. Apparently the guy before him had it Turbo charged cause there's all this aftermarket junk on there, Msd ignition crap, adjustable fuel pressure switches and gauges, Skunk2 Intake manifold, and w/e else. Well his CEL wont go off in this car. The computer says it has to do with the O2 sensor. we have tried cleaning it and such and it has done nothing then he had some mechanic put some crap on there to bypass it, a mill elimnator or w/e and it also has done nothing. The bad part is he needs a state inspection, and cannot get one with the problems because of emissions. So is there some other thing causing this CEL or should he just be a man about it and cough up 200$ for a new O2 sensor? I think personally its more than just the sensor thats why the person who was selling it was selling it.
Old Mar 8, 2006 | 01:37 PM
kyden's Avatar
Default Re: 2000 SI CEL (preluderacecar)
uh.. pull the code..
Old Mar 8, 2006 | 01:45 PM
Rocket Man's Avatar
Default Re: 2000 SI CEL (kyden)
its the code for the O2 sensor i said that read
Old Mar 8, 2006 | 01:57 PM
upstatee's Avatar
get a used one off here.
Old Mar 8, 2006 | 02:09 PM
NAem1's Avatar
Default Re: 2000 SI CEL (upstatee)
which o2 sensor? You said you cleaned the sensor (if you cleaned the right one), have you tried just replacing it?
CGcivicGSR
Apr 17, 2012 02:40 PM
roflcopterdown
10
Oct 27, 2007 10:07 PM
HybridCoupe
Aug 29, 2002 09:57 AM
PurpleGsR00
Jun 27, 2002 08:27 PM
