95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!!
Old Mar 8, 2006 | 01:14 PM
ricekiller1's Avatar
Default 95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!!
apparently there are a couple differant part numbers for these 2 parts..i just need the flanges to match up...they are goin in my accord to pass smog but im not about to spend 800 on the WRONG PARTS THAT I CANT RETURN....please help me....
Old Mar 8, 2006 | 02:27 PM
NAiL05's Avatar
Default Re: 95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!! (ricekiller1)
Why dont you go to the dealership and ask?
Old Mar 9, 2006 | 01:59 PM
Default Re: 95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!! (NAiL05)
been there, done that...i have a good friend tht is a honda parts guy..he says there are numerous part numbers for those parts...i need a usdm prelude dohc vtec vin number i think
Old Mar 9, 2006 | 04:43 PM
sinister2c's Avatar
What car are you trying to put the H22 and header on?
If it is a 94-97 Accord...you can use a 98 Prelude SH header and it will bolt right up to the Accord Cat.
Old Mar 9, 2006 | 05:26 PM
Default Re: 95 h22 OEM downpipe and cat part numbers??? PLEASE!!!!! (sinister2c)
well its a 1994 accord and im runnin a sh downpipe and a testpipe....but need to pass smog inspection...so im gettin the CORRECT downpipe to match up with the CORRECT cat....and im also gettin rid of this hack *** bracket that was fabricated to hold my downpipe to my block because i can just use the stock bracket when i get the correct downpipe
Old Mar 9, 2006 | 05:32 PM
sinister2c's Avatar
the stock SH down pipe attaches to the stock Accord EX Cat and lil extension piece with the O2 in it.
Old Mar 9, 2006 | 05:36 PM
dont have the accord cat any more...it was an LX accord..and i think i would be a little more comfortable goin to a smog test with the right cat for the engine considering i have a jdm h22...plus i get honda parts at cost
Old Mar 9, 2006 | 06:54 PM
sinister2c's Avatar
you are out of luck because I do not know of any other setup that will allow you to use a stock cat/header set-up.
The 93-96 H22 header will only line up with the 90-93 accord head/exhaust setup.
The 94-97 Accord EX cat/SH header is the only other setup I know of.
Anything else will be cut and paste by a muffler shop.
Old Mar 10, 2006 | 12:55 PM
i have the stock header...im just gonna get the (95 dohc vtec) usdm downpipe and cat and weld up the backside of the exhaust as needed...this should work??? right??? i was just havin a problem gettin the part numbers....
Old Mar 10, 2006 | 09:37 PM
sinister2c's Avatar
yes that will work
http://www.slhondaparts.com
tkhang
Jul 10, 2010 02:05 PM
spawn_f20b
Jul 5, 2009 09:36 PM
ricekiller1
Mar 9, 2006 04:55 PM
driftt
Aug 26, 2005 07:30 PM
Accord94DX
Feb 4, 2002 07:21 AM
