OBDIIA DLC problem
i have a 97 EK w/ a 99 b16a2, running a p72 obd2 ecu. i've done searches upon searches and i don't see anyone with the same problem as me.
The problem: when plugging a OBDII scanner into the DLC the scanner reads "FAIL".
I also brought my car to smog, and they were unable to read from the DLC as well. Now my question is...why? or How come? it is unable to read? what could be the problem?
I would suggest you first check the haress to the ecu and to the DLC. next make sure all 16 pins on the DLC is connected. sometimes one of the pin can be disconnected. You should get battery power from Pin 16 on the DLC connector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BUNNYz »</TD></TR><TR><TD CLASS="quote">I would suggest you first check the haress to the ecu and to the DLC. next make sure all 16 pins on the DLC is connected. sometimes one of the pin can be disconnected. You should get battery power from Pin 16 on the DLC connector.</TD></TR></TABLE>
actually there are only 5 pins on the connector. I've verified that this is normal, because on my friends 99 Si he has the same exact number of pins, and his reads with the scanner. I think the ECU might be the culprit. but i'm still unsure of what else could be the problem, or what i can do to fix it. *scratches head*
the 8thgen hybrid men45mpg yo
2muchVTEC
Apr 9, 2008 03:02 PM
