b18c1 to type r spec?
Old Mar 31, 2002 | 10:38 AM
spork sport's Avatar
Default b18c1 to type r spec?
my friend has a '94 gsr, now he wants to change his engine to type r spec
what's needed to be done?
i only know of cams, intake manifold n port n polish
Old Mar 31, 2002 | 10:41 AM
B18 B e a s T's Avatar
Default Re: b18c1 to type r spec? (1.6se)
transmission, type r pistons, headers and exhaust if he wants. . . .
Old Mar 31, 2002 | 10:42 AM
RagingAngel's Avatar
pistons.... or compression for that matter
valves, valvesprings....
lost motion assemblies....
Old Mar 31, 2002 | 11:23 AM
Default Re: b18c1 to type r spec? (RagingAngel)
without the tranny n port n polish job
how mcuh hp would that be? given that i has all type r internals, ie pistons, valve springs, cams, intake manifold....etc...
n how mcuh, i guess he's looking for used parts
Old Mar 31, 2002 | 11:25 AM
Reid's Avatar
Global Moderator
If he wants to run an ITR intake manifold he needs to switch to a B16/ITR head.
Old Mar 31, 2002 | 11:34 AM
Ausmith's Avatar
https://honda-tech.com/zerothread?id=149611
Old Mar 31, 2002 | 11:46 AM
hooptie157's Avatar
Default Re: b18c1 to type r spec? (Ausmith)
http://www.modacar.com used to have a type R conversion package for a b18c1 butI can't seem to find it on their website, if you call them they will probably still have that package in stock, sorry I couldn't help more
Old Mar 31, 2002 | 12:00 PM
ITRbroham's Avatar
shit post warrior
Default Re: b18c1 to type r spec? (hooptie157)
A friend of mine Type R' ed his B18C1, of course with legit parts!
He has the complete ITR valvetrain, pistons, oil squirters, headgasket, crankshaft, and tranny. He kept the GSR's intake and head for it's increased low and midrange torque. With the this setup the motor will run almost 12 points compression so he added another headgasket to lower it and runs a chipped OBD1 ECU.
Old Mar 31, 2002 | 12:36 PM
Stunna BEN's Avatar
Don't call it a comeback
Bad *** car Ausmith!!!
Old Mar 31, 2002 | 04:24 PM
Default Re: b18c1 to type r spec? (LunEG)
what if i just get itr valvetrain, pistons, cams, tb, headgasket, polish intake manifold, how much power will i get approximatly?
my friend alreayd has cai, 421 header, catback
Old Mar 31, 2002 | 04:28 PM
Reid's Avatar
Global Moderator
No one can give you an accurate estimate, but your friend needs to get a better header if he wants to make more power. JDM 4-1 is a cheap solution. Just dyno it, that's the only way he'll know how much power he's making.
Old Mar 31, 2002 | 05:09 PM
BERT-O's Avatar
does that make a big different ?, i know is a different part # than the b16 heads but wasn't sure it would make a different.
just wondering......
Old Mar 31, 2002 | 05:14 PM
Agamemnon's Avatar
New User
I remember that too. It was a spoon type r conversion kit, I cant remember exactly what came with it, but it was a lot of coin though.
Old Mar 31, 2002 | 05:42 PM
xtrafastcivic's Avatar
Default Re: b18c1 to type r spec? (Devin)
fack type r conversion. that's gay!!!!!!! do something else something better i hate people that have a ls gsr whatever i want a type r!!! i know i'll put a bunch of these parts in and make it a type r don't disgrace the name type r it's a rare piece of machine atleast here in the states so tell your friend to make his car better so he can beat those cocky type r owners sorry to non cocky type r owners
Old Mar 31, 2002 | 06:08 PM
Default Re: b18c1 to type r spec? (XtraFastCRX)
WTF???
he's not gonna put type r sitckers on the car
he just want more power, n he doesn't have lots of cash to spend
Old Mar 31, 2002 | 06:14 PM
Reid's Avatar
Global Moderator
Well cars are a very expensive hobby, don't think there's any route that's "cheap" by any means.
Old Mar 31, 2002 | 06:29 PM
Default Re: b18c1 to type r spec? (Reid)
what oh i mean is he can afford to change to type r spec
but nothing like a turbo/sc or aftermarket cams/valvetrain, things like that
Old Mar 31, 2002 | 06:42 PM
Reid's Avatar
Global Moderator
ITR spec may end up costing him more than aftermarket cams/valvetrain.
Old Mar 31, 2002 | 07:38 PM
how is that?
i think he's just lookng for used.....
Old Apr 1, 2002 | 02:42 AM
Ausmith's Avatar
Default Re: b18c1 to type r spec? (ITRbroham)
Here is my perspective on your friend's issue...
Doing a complete Type R conversion (properly mind you) is going to cost pretty big money. The first thing I would do is look to spend some money on tuning. Get a VAFC, Cam gears, do basic tune-up stuff and hit the dyno.
My B18C1 baselined at 140whp with basic bolt ons. With a few mionor changes to fuel and timing we were able to get 150whp.
If you really want to change parts there are 3 places to look for power on that motor:
1)Cams
2)Manifold (skunk)
3)Compression (headgasket, pistons, shave)
If you are on a budget I would look into #1 and #3. Find a pair of used CTR cams for $300 (that's what I paid for mine). Pull the head and take it to a machine shop and have it tanked, valve job, and shaved .040". Put it back together with a thin headgasket ($130) and the new cams. Hit the dyno.
If you do the manifold you'll need a new ECU program also.
cams = $300
gasket = $130
manifold = $300
ecu = $200
machine work = $500
cam gears = $300
VAFC = $300
You can see that even the most basic conversion is expensive.
One more point here.... Whatever you do, keep the GSR rocker arms! They have a mor agressive ratio than the ITR/B16, so you'll end up getting slightly more out of a cam.
Good luck.
Thanks LunEG!
leroyb
Mar 16, 2008 10:04 AM
poormans_typer69
27
Sep 25, 2006 06:52 PM
B18cHatch06
Dec 9, 2004 06:37 PM
DPK
Nov 21, 2003 08:18 AM
91cvcsi
Apr 30, 2002 04:47 PM
