92-95 eg, S2000 cluster. Temp Gauge doesnt work?
Old Mar 8, 2006 | 06:11 AM
Crank's Avatar
Default 92-95 eg, S2000 cluster. Temp Gauge doesnt work?
Help needed, I'am doing a S2000 cluster in my eg and ran into this one problem(Besides the speedo..). Help will be greatly apreciated. thanks fellas
Old Mar 8, 2006 | 06:43 AM
NJcoupe's Avatar
Default Re: 92-95 eg, S2000 cluster. Temp Gauge doesnt work? (Crank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Crank &raquo;</TD></TR><TR><TD CLASS="quote">Help needed, I'am doing a S2000 cluster in my eg and ran into this one problem(Besides the speedo..). Help will be greatly apreciated. thanks fellas</TD></TR></TABLE>
Hate to be the first to say it, but search. there is at least 10 threads going on about s2000 cluster swaps.
Old Mar 8, 2006 | 08:09 AM
Crank's Avatar
Default Re: 92-95 eg, S2000 cluster. Temp Gauge doesnt work? (idriveacoupe.)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by idriveacoupe. &raquo;</TD></TR><TR><TD CLASS="quote">Hate to be the first to say it, but search. there is at least 10 threads going on about s2000 cluster swaps.</TD></TR></TABLE>
been there, couldnt find the info i need..
Old Mar 8, 2006 | 09:09 AM
Crank's Avatar
Old Mar 8, 2006 | 07:33 PM
Crank's Avatar
bump
Old Mar 16, 2006 | 08:46 PM
FULL throTTLe's Avatar
just follow other cars
Old Mar 17, 2006 | 12:51 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (FULL throTTLe)
been there, couldnt find the info i need.. </TD></TR></TABLE>
I guess you didn't look too well. Anyways, I believe the temp gauge will not work. Its data-bus based, not voltage. You will need a "conversion box" of sorts to get the non-functional gauges, functional.
Edit: Found it in less than 5 seconds.
https://honda-tech.com/zerothread?id=1180369
Old Mar 19, 2006 | 07:01 PM
bigcalidave's Avatar
Here is the solution you wanted. And yes, there are tons of other threads about the cluster swap with almost ZERO information. Somebody get the ball rolling and it'll be ok.
Buy one of these. Voila, Temp gauge works.
http://www.modifry.com/products/ect/index.htm
speedfreak44
Nov 26, 2010 10:29 PM
xxdevilzeroxx
Mar 1, 2010 05:30 AM
crx^2yosolo
14
Dec 27, 2005 05:42 PM
mugenhatchie
20
Nov 5, 2005 08:56 PM
