obd1 question
Old Mar 8, 2006 | 05:48 AM
EF9ZC's Avatar
Default obd1 question
Ok i have an obd1 dizzy with obd0 computer and i'm pretty sure reason its throwing codes is because of this exact thing but the mechanic is trying to convince me that the codes are because its a shotty dizzy so can someone confirm this for me about the obd1 dizzy and obd0 ecu
Old Mar 8, 2006 | 06:02 AM
crx_88_si's Avatar
obd1 dist cannot work w/ obd0 ecu and vise-versa.
reason: one of the pickups has 12 teeth for obd1 and the obd0 one has 16. or whatever the actual numbers are, but the reason is accurate.
Old Mar 8, 2006 | 07:04 AM
EF9ZC's Avatar
i dont understand 12 teeth? If i run wires straight to dizzy with no harness your saying it won't work you mean volts or teeth?
Old Mar 8, 2006 | 07:10 AM
si0385.'s Avatar
Default Re: (EF9ZC)
teeth... there are gears inside the distributor
are the plugs on your distributor off white or grey?
what ecu are you running?
Old Mar 8, 2006 | 07:33 AM
EF9ZC's Avatar
i got the stock d16a6 one i think its pm06 or something. I got the d16z6 dizzy and its throwing crank angle sensor and tdc
Old Mar 8, 2006 | 07:36 AM
si0385.'s Avatar
Default Re: (EF9ZC)
the stock ecu is a pm6 and im sorry but you dont have a z6 dizzy you have an a6 one...
and if its throwing those codes your gona need a new distributor most likely
Old Mar 8, 2006 | 07:44 AM
EF9ZC's Avatar
yo i got a vtec head on my a6 block lol i know what i have im telling u i have a d16z6 dizzy with a d16z6 head with a d16a6 block with a pm6
Old Mar 8, 2006 | 02:33 PM
EF9ZC's Avatar
bump so i can spread some knowledge to me and guy helping me why won't obd1 dizzy work with obd0 computer thanks
Old Mar 8, 2006 | 03:24 PM
si0385.'s Avatar
ok than you have an a6 block with a z6 head with the a6 distributor that is notched on the top leg and the leg in the front of the motor to fit on the head... unless its converted to obd1 in witch case you are not running a pm6
find out what you have for sure than we can help you out
unless the ecu is chiped its impossible to run an obd1 dizzy off of an obd0 ecu
Old Mar 8, 2006 | 04:22 PM
EF9ZC's Avatar
Man look i got an a6 block with a z6 head and z6 dizzy. The a6 dizzy wouldn't fit and won't fit without modification. I got a pm6 ecu and ran the wires straight to each other with no harness if you dont believe me ill take a freaking picture. All i want to know is why it won't work.
Old Mar 8, 2006 | 04:25 PM
si0385.'s Avatar
Default Re: (EF9ZC)
a pic would actually help
than your converted to obd1? thats what i was asking in the beginning
Old Mar 8, 2006 | 04:28 PM
ILcrxsi1's Avatar
I tell doctors what to do
get a new ecu
Old Mar 8, 2006 | 04:59 PM
EF9ZC's Avatar
Ok look i got a pm06 ecu i cut off the harness on the dizzy and the wires going to the dizzy used a wire print out to figure out which one go to which. And i just wana know whats the difference between a obd1 and obd0 dizzy
88EDHatch
Nov 12, 2010 11:27 AM
VegasInvasion
Jul 1, 2010 10:49 AM
whitecivic11
Mar 28, 2010 11:04 AM
dougshatch
Jun 14, 2007 12:41 PM
Maddox
10
Apr 11, 2004 11:24 AM
