2000 si motor swap
Old Mar 7, 2006 | 09:11 PM
94excoupeSA's Avatar
Default 2000 si motor swap
does a 2000 si motor drop right in a 97 hatch no problem like do u have to do any wiring
Old Mar 7, 2006 | 09:22 PM
B18C EG2's Avatar
From: Home Of The Players And PIMPS, IN, united states
Default Re: 2000 si motor swap (94excoupeSA)
wiring for 99-00 isn't compatible...must use 96-98 harness preferably your stock harness....you'll need the 99-00 back mount off the Si too....96-97 delsol ECU too...other then that your golden..
Old Mar 7, 2006 | 09:26 PM
Default Re: 2000 si motor swap (Stupid EK)
yea i was thinking that then converting to obd 1
Old Mar 7, 2006 | 09:27 PM
i was just wondering if it was possible have u done one or no
Old Mar 7, 2006 | 09:40 PM
B18C EG2's Avatar
i dono what your asking....you can use the 99-00 harness.....but its more hassel then its worth....it includes way more wiring and splicing? your better of just using the 97 DX harness. you can convert to obd1 using a conversion harness after that but i always reccomend using the ecu for the year of the car. I hate those conversion harness's cause i've had bad luck with them.
notes
Use your stock 97 harness
Use conversion harness from obd2a to obd1 with p30 ecu
or use a p30 for obd2a
also you will need the backmount off the Si
i've already put an b16a2 in my car and it ran good....but it was torqueless and i took it out...now i have a b18 in my 98 hatch and it runs CEL Free....gl
civic46
Oct 27, 2010 08:22 AM
EKcivicEK
Oct 25, 2009 09:00 AM
808kyle808
12
Mar 13, 2009 07:24 PM
B16a2inintegra
Oct 20, 2005 06:37 PM
bradykiller
Sep 19, 2005 09:43 AM
