depo fog question
Old Mar 7, 2006 | 05:06 PM
zacatkings's Avatar
Default depo fog question
i just put my depo fogs last night and today my right one is out? has anyone had this problem? i know its probally the bulb but i just put them in last night and wondering if there is any common problems with them
Old Mar 7, 2006 | 05:21 PM
zacatkings's Avatar
Default Re: depo fog question (zacatkings)
up
Old Mar 7, 2006 | 05:40 PM
BlueIntegraBoy's Avatar
Check the plug connections
Old Mar 7, 2006 | 05:45 PM
SILVER97EX's Avatar
ive got depo fogs, no problems yet(knock on wood) but then again it has only been about 3 weeks.
Old Mar 7, 2006 | 06:30 PM
hondaboy4life's Avatar
Default Re: (SILVER97EX)
like that guy said just check the plug that plugs from the harness into teh back of the fog light. i had a wire come out of the connector. Also just take a simple volt meter and start testing power and grounds lol. Thats what i did.
Old Mar 7, 2006 | 08:53 PM
john666's Avatar
check connections.. depo ones are coo common problem tho is the relay. so keep that in mind for later... usally water gets into it and then the lights dont work so mount it in a spot that doesnt get too wet
Old Mar 7, 2006 | 09:23 PM
zacatkings's Avatar
Default Re: depo fog question (john666)
thanks for the info
Old Mar 7, 2006 | 10:52 PM
ekfkn9's Avatar
a wassup man. i had the same problem..mines was the 2pin connector to the fog light. it was getting a bad connection. all i did was cut the connectors off on both ends and crimped on male and female connectors. should be all good after that. if not bulb probably juss blew. i would juss check the connection first..aight then man
Old Mar 8, 2006 | 12:42 AM
turboDeznutz's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SILVER97EX &raquo;</TD></TR><TR><TD CLASS="quote">ive got depo fogs, no problems yet(knock on wood) but then again it has only been about 3 weeks.</TD></TR></TABLE>
4 the depos no probs yet 3 months strong
94 accord typeR
Lighting
Feb 9, 2015 06:03 PM
awdgsx96
Jul 21, 2009 06:38 AM
taimysho0
17
Jan 17, 2009 12:05 PM
treylittlet0n
Honda Civic (2006 - 2015)
Aug 18, 2007 05:01 PM
95civickid
Mar 12, 2005 12:43 AM
