help wit codes on a gsr engine
Old Mar 7, 2006 | 02:18 PM
civic4u2envy87's Avatar
Default help wit codes on a gsr engine
ok i just did a gsr swap into a eg civic its a ex but the engine it had b4 was a d15b7 if it helps .. the gsr engine is a 95 . wen we finished the swap there was one plug extra on the engine harness its a plug wit 2 wires i think its a red wire and a black one not sure will confirm later on tonight.. then i got a knock sensor code but iheard if u got a knock sensor cose ur vtec wont hit and mine is kicking in.. and i also have a heated oxyegen code wat can i do to fix this .. im running a p72 ecu supossbley its stock but vtec kicks in at 4500 rpmz ...all i also need to know where do i find the dual buterflies wires on the engine harness wat color are they i need to hook them up i kno where they go to ecu but dont know where the wires wre at.
Modified by civic4u2envy87 at 4:46 PM 3/7/2006
ek_silverback
May 25, 2011 07:48 PM
jdm_sai
Jul 18, 2010 06:05 AM
myDC4rox
Jan 9, 2005 06:54 AM
speshuled619
Jul 26, 2002 05:18 AM
