cams ctr vs itr
Old Mar 7, 2006 | 09:12 AM
GsR92HaTcH's Avatar
Default cams ctr vs itr
pros an cons on them someone told me taht itr cams are for more torque but i dunno but im lookin for cams for my gsr and i need some help...i found some ctr cams for 200 and itr for 220 so i need help
Old Mar 7, 2006 | 09:13 AM
Soccerking3000's Avatar
Default Re: cams ctr vs itr (GsR92HaTcH)
i beleive they are the same thing, i might be wrong though
Old Mar 7, 2006 | 09:48 AM
A.E Motoring's Avatar
the exhaust side is the same, its the intake side thats different, or visa versa, i have CTRs in my GSR, i like them
Old Mar 7, 2006 | 09:50 AM
EK k kay's Avatar
Default Re: cams ctr vs itr (SPNFEDEH)
I thought the later model ITR cams were nearly identical on the intake cam?
Old Mar 7, 2006 | 09:52 AM
Default Re: cams ctr vs itr (EK k kay)
possibly, i could be wrong
Old Mar 7, 2006 | 10:25 AM
6SPD_EK's Avatar
00-01 ITR cams SUPPOSEDLY are the same as CTR (there was rumor that the '00+ ITR was 1 degree less than CTR in duration)
95-99 ITR cams SUPPOSEDLY have 3 degrees less duration (intake cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR92HaTcH &raquo;</TD></TR><TR><TD CLASS="quote">pros an cons on them someone told me taht itr cams are for more torque but i dunno but im lookin for cams for my gsr and i need some help...i found some ctr cams for 200 and itr for 220 so i need help</TD></TR></TABLE>
ITR cams for more torque is PURE BS.... its the 1.8L ITR block that gives that motor more torque than the b16b CTR 1.6L block
before you get ripped off for cams make sure you get good pics of the distributor end of the intake cam & make sure engraved & protruding rings match up
see https://honda-tech.com/zerothread?id=1220152
those prices you mentioned were they for set or for intake cam only...price is too good to be true for both int & exh cams...too many people these days are selling b16a or b18c1 cams & trying to pass them off as ITR/CTR ones
Old Mar 7, 2006 | 10:42 AM
honda head's Avatar
CTR intake cam has a slightly bigger duration at 243 while the ITR intake cam has a duration of 240. Both the CTR and ITR intake cams have the same amount of lift at 11.5mm. the exhaust cams are completely identical with a duration of 235 and 10.5mm of lift... yeah, can ya tell... i have no life..jk
Old Mar 7, 2006 | 10:58 AM
6SPD_EK's Avatar
Default Re: (honda head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda head &raquo;</TD></TR><TR><TD CLASS="quote">CTR intake cam has a slightly bigger duration at 243 while the 95-99 ITR intake cam has a duration of 240. Both the CTR and ITR intake cams have the same amount of lift at 11.5mm. the exhaust cams are completely identical with a duration of 235 and 10.5mm of lift... yeah, can ya tell... i have no life..jk </TD></TR></TABLE>
I edited your post (see bold)
Old Mar 7, 2006 | 12:35 PM
JeRkBeBOT's Avatar
AKA MoDeL FaWken JERKz
Default Re: (adirondackR)
Old Mar 7, 2006 | 05:59 PM
mtownsi's Avatar
yo wats good . were did u find ctr cams for that cheap let me know the site
Old Mar 7, 2006 | 06:05 PM
GsR92HaTcH's Avatar
craigslist.com....so you think theyll be pretty much the same...so i should just go with what i find cheaper?
Old Mar 13, 2006 | 01:23 PM
burnt_rice's Avatar
nope they aren't the duration on the intake cam is longer w/ctr's than itr's the exhuast are identical
Old Mar 13, 2006 | 01:33 PM
RTI's Avatar
RTI
Default Re: cams ctr vs itr (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR &raquo;</TD></TR><TR><TD CLASS="quote">00-01 ITR cams SUPPOSEDLY are the same as CTR (there was rumor that the '00+ ITR was 1 degree less than CTR in duration)
95-99 ITR cams SUPPOSEDLY have 3 degrees less duration (intake cam) </TD></TR></TABLE>
I didn't know there was an ITR in 1995.
Old Mar 13, 2006 | 11:08 PM
GsR92HaTcH's Avatar
no i mean there pretty much gonna be the same for hp???so i should jsut go with what i find cheaper
Old Mar 14, 2006 | 12:30 AM
teknoracing's Avatar
Default Re: (GsR92HaTcH)
Those prices are probably for either the intake cams or exhaust cams, because the retail high 300's each.
SilverEK96
Apr 24, 2012 08:52 AM
kenepo_vtec
Jul 4, 2004 08:57 PM
lo0nY
30
Mar 11, 2004 12:20 AM
JDMlyfestyle
Nov 1, 2003 06:26 PM
PrOjEkT ED9
Sep 2, 2002 02:40 PM
