cams ctr vs itr
cams ctr vs itr
pros an cons on them someone told me taht itr cams are for more torque but i dunno but im lookin for cams for my gsr and i need some help...i found some ctr cams for 200 and itr for 220 so i need help
Re: cams ctr vs itr (EK k kay)
00-01 ITR cams SUPPOSEDLY are the same as CTR (there was rumor that the '00+ ITR was 1 degree less than CTR in duration)
95-99 ITR cams SUPPOSEDLY have 3 degrees less duration (intake cam)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by GsR92HaTcH »</TD></TR><TR><TD CLASS="quote">pros an cons on them someone told me taht itr cams are for more torque but i dunno but im lookin for cams for my gsr and i need some help...i found some ctr cams for 200 and itr for 220 so i need help</TD></TR></TABLE>
ITR cams for more torque is PURE BS.... its the 1.8L ITR block that gives that motor more torque than the b16b CTR 1.6L block
before you get ripped off for cams make sure you get good pics of the distributor end of the intake cam & make sure engraved & protruding rings match up
see https://honda-tech.com/zerothread?id=1220152
those prices you mentioned were they for set or for intake cam only...price is too good to be true for both int & exh cams...too many people these days are selling b16a or b18c1 cams & trying to pass them off as ITR/CTR ones
CTR intake cam has a slightly bigger duration at 243 while the ITR intake cam has a duration of 240. Both the CTR and ITR intake cams have the same amount of lift at 11.5mm. the exhaust cams are completely identical with a duration of 235 and 10.5mm of lift... yeah, can ya tell... i have no life..jk
Re: (honda head)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by honda head »</TD></TR><TR><TD CLASS="quote">CTR intake cam has a slightly bigger duration at 243 while the 95-99 ITR intake cam has a duration of 240. Both the CTR and ITR intake cams have the same amount of lift at 11.5mm. the exhaust cams are completely identical with a duration of 235 and 10.5mm of lift... yeah, can ya tell... i have no life..jk </TD></TR></TABLE>
I edited your post (see bold)
Re: cams ctr vs itr (adirondackR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adirondackR »</TD></TR><TR><TD CLASS="quote">00-01 ITR cams SUPPOSEDLY are the same as CTR (there was rumor that the '00+ ITR was 1 degree less than CTR in duration)
95-99 ITR cams SUPPOSEDLY have 3 degrees less duration (intake cam) </TD></TR></TABLE>
I didn't know there was an ITR in 1995.
SilverEK96
04-24-2012 08:52 AM
