Turbo miata bucking, missing, blowing out spark? under boost
Old Mar 6, 2006 | 07:12 PM
T25So's Avatar
Default Turbo miata bucking, missing, blowing out spark? under boost
Hi guys,
I just recently had a new manifold fab'd for my miata so I could run an external wastegate. Now that the cars back, im having a problem. When I get into boost, I will hear a sound like a freaking shotgun, and the car will lose all power. I checked the plugs, and they are bright white after only about an hour of it running. Sounds like a fuel issue? The only thing I could think of is that I ran the vacuum for the fpr t'd off the bov line, which draws vacuum from the mani. Also, I wish I could have a cel, but im running haltech. Any suggestions?
Old Mar 6, 2006 | 07:16 PM
I Have an STD's Avatar
wrenchin'
Default Re: Turbo miata bucking, missing, blowing out spark? under boost (T25So)
white plugs= super lean. u need to get a wideband on that thing and see what your AFRs are. looks like u have a serious fuel problem or need a re-tune
Old Mar 6, 2006 | 07:21 PM
T25So's Avatar
Definately...It seems to run fine part throttle, its just under boost. The problem im having is that it was fine before I took it in, so im not sure what could have made it run so lean.
Old Mar 6, 2006 | 07:22 PM
T3T495GSR's Avatar
Default Re: (T25So)
Some jackass at the dealership probably hotrodded your car around town like on "ferris buelers day off"
Old Mar 6, 2006 | 07:26 PM
T25So's Avatar
lol, nah, I had the battery out and the throttle cable disconnected...it was also at a very reputable shop called autolab, which some may know.
Old Mar 6, 2006 | 07:37 PM
DaveF's Avatar
Default Re: (T25So)
maybe something is not hooked up properly.
Old Mar 6, 2006 | 07:50 PM
T3T495GSR's Avatar
Default Re: (Dturbocivic)
D turbo you changed your avatar i noticed
Wuman
Sep 13, 2009 07:02 PM
cliff666
Aug 1, 2004 11:04 AM
QUICKERSILV3R
Dec 28, 2003 06:24 AM
delslow94
Oct 27, 2003 02:07 PM
