99-00 EX v.s Si suspension same???
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gear_e »</TD></TR><TR><TD CLASS="quote">what's the difference between 99-00 Civic Si stock suspension and 99-00 Civic EX stock suspension (both springs and struts)?</TD></TR></TABLE>
13mm back, 26mm front
the EX doesnt even come with a rear sway bar. I know mine didnt. I dont think the EX came with a front sway bar either....but it does come with all the factory holes for easy Si > EX suspension upgrade.
Spring rates for the ex are 165f/80r and the si are 200f/99r. Shocks are the same.
---The ex has a 22mm front , no rear sway bars. Not counting the ex with abs, that has a 13mm rear. The si, as previously stated, has a 26mm front and a 13mm rear. IIRC the si has different front lcas that you need in order to use the si front bar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 »</TD></TR><TR><TD CLASS="quote">Not counting the ex with abs, that has a 13mm rear. </TD></TR></TABLE>
nope
nope
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Voyage34 »</TD></TR><TR><TD CLASS="quote">Spring rates for the ex are 165f/80r and the si are 200f/99r. Shocks are the same.
---The ex has a 22mm front , no rear sway bars. Not counting the ex with abs, that has a 13mm rear. The si, as previously stated, has a 26mm front and a 13mm rear. IIRC the si has different front lcas that you need in order to use the si front bar</TD></TR></TABLE>
Everything he said, plus the Si's front damper forks are wider to fit the larger "stamped steel" style LCA.
If you want an Si front bar on your EX, you will need the complete lower suspension (sway-bar, end-links, bushings, LCAs, damper forks)...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sicones »</TD></TR><TR><TD CLASS="quote">nope </TD></TR></TABLE>
My bad that was the EG sedan w/abs that has the rear bar. wrong gen
creepy116
Apr 10, 2008 11:54 PM
turq93t
May 21, 2006 04:25 PM
EricUSC
Sep 30, 2003 10:41 PM
99, 9900, civic, damper, diff, difference, ek, fit, fork, honda, shocks, si, suspension, suspention, whats
