After the rear disc conversion
Old Mar 6, 2006 | 09:28 AM
fraknstien's Avatar
Default After the rear disc conversion
Ok, so I just got done with my rear disc conversion on my 97 dx hatch
I believe the trailing arm was from a teg and i also used my civics lower control arms.
But when I drive, my car doesn't drive straight (my rear tends to pull side to side) so i have to turn my steering wheel slightly to make my car go straight...
I really noticed this yesterday because the snow made it difficult to drive..
I have no idea why ..
and i just got an alignment yesterday too
Any Ideas?
Old Mar 6, 2006 | 09:33 AM
Neebs's Avatar
You need to do an alignment I believe. Anything you do to suspension you need to align it.
Old Mar 6, 2006 | 09:36 AM
JDM_Ej's Avatar
HT Order of Merit
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: (Neebs)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Neebs &raquo;</TD></TR><TR><TD CLASS="quote">You need to do an alignment I believe. Anything you do to suspension you need to align it.</TD></TR></TABLE>
Bingo.
Old Mar 6, 2006 | 09:55 AM
kaiba's Avatar
Default Re: After the rear disc conversion (fraknstien)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fraknstien &raquo;</TD></TR><TR><TD CLASS="quote">
Any Ideas? </TD></TR></TABLE>
Maybe the trailarm are bend
Old Mar 6, 2006 | 02:00 PM
fraknstien's Avatar
Default Re: After the rear disc conversion (kaiba)
im not sure if they're bent but lets say they weren't... any other reasons? thanks
Old Mar 6, 2006 | 02:24 PM
kaiba's Avatar
Check the trailarm bushing.
Old Mar 6, 2006 | 02:32 PM
EK k kay's Avatar
One of the trailing arms may be bent.
Old Mar 6, 2006 | 02:36 PM
postman's Avatar
alignment done incorrectly, if you took it somewhere where they know what there doing, they should have caught any bent or worn or broken pieces even before starting the alignment, they might just not have centerd your steering wheel correctly when adjusting your toe
Old Mar 7, 2006 | 07:49 AM
fraknstien's Avatar
Default Re: After the rear disc conversion (postman)
ok im guessing that it's my trailing arm bushing are bad.. but what are some symptons for bad bushings?
Old Mar 7, 2006 | 08:06 AM
themorphious's Avatar
if you just got the alignment, then i would say that they screwed up, tell them that it's still pulling one way.....and they SHOULD redo it for you.....make sure they know you came in the day before and got an alinment......they will know when they put it on the rack if it's still out of alignment....sometimes they will just get the numbers close and it'll amke the car drive funny...like the steering wheel wasnt aligned properly..or sometimes they just forget to check everyhting one more time...
alscrx
11
Mar 26, 2008 02:31 PM
Ex Member
Aug 3, 2006 12:00 PM
eg:R
Jan 29, 2006 06:50 PM
b20bvtec'd
Mar 28, 2005 07:59 PM
eghatchproject
Mar 16, 2004 07:05 AM
