Need help launching
Old Mar 6, 2006 | 05:22 AM
Jamied's Avatar
Default Need help launching
okay, my car is a 2000 Civic SI
my mods:
DC Sports catback
DC Sports Header
AEM CAI
Short Shifter
i ran at the track yesterday..
15.8 @ 87 mph
15.9 at 90 mph
i am having trouble off the line and want to know where i should be launching at?
Old Mar 6, 2006 | 06:15 AM
mek9fast's Avatar
Default Re: Need help launching (Jamied)
depends the situation. your probably running street tires right. i normally launch around 5500 around where vtec kicks in.
Old Mar 6, 2006 | 06:19 AM
hondachris1994's Avatar
Default Re: Need help launching (mek9fast)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mek9fast &raquo;</TD></TR><TR><TD CLASS="quote">depends the situation. your probably running street tires right. i normally launch around 5500 around where vtec kicks in.</TD></TR></TABLE>try launching around 4000.Launching at 5500 will make u spin out
Old Mar 6, 2006 | 06:21 AM
civexturbo's Avatar
What were your 60' times?
Old Mar 6, 2006 | 06:58 AM
huntarrr's Avatar
Default Re: (civexturbo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civexturbo &raquo;</TD></TR><TR><TD CLASS="quote">What were your 60' times?</TD></TR></TABLE>
Old Mar 6, 2006 | 07:02 AM
Soccerking3000's Avatar
Default Re: (vsm98civic)
i would post this in the drag forum might get more answer there, just a suggestion.
Old Mar 6, 2006 | 07:23 AM
hondapowa's Avatar
What was your launch this run? What was the car's attitude? There is not enough info given by you to give a good analysis.... More info please!
Old Mar 6, 2006 | 07:43 AM
1dumbscreenname's Avatar
Default Re: (hondapowa)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by hondapowa &raquo;</TD></TR><TR><TD CLASS="quote"> What was the car's attitude? More info please! </TD></TR></TABLE>
Yeah, was your car in a good or bad mood?!?!
Old Mar 6, 2006 | 09:55 AM
Jamied's Avatar
my 60's were around 2.5
yes i am on street tires...
i launched around 3000 and 3500..should i try higher?
i wheel hopped like all the way through first..anything i can do for that?
Old Mar 6, 2006 | 10:16 AM
SkoundrelUSA's Avatar
cute little bastard
Default Re: (Jamied)
did you slip or pop the clutch?
Old Mar 6, 2006 | 10:17 AM
Jamied's Avatar
what do u mean by that?
Old Mar 6, 2006 | 10:19 AM
cute little bastard
Like did you just let the clutch release (pop) or did you ease off it slowly (slipped) ?
Old Mar 6, 2006 | 10:22 AM
civexturbo's Avatar
2.5 isn't real great for a 60' time. Drag radials will get you around a 2.2-2.0. Wheel hop is also a killer, try adjusting your tire pressure to help a little bit.
Old Mar 6, 2006 | 10:32 AM
Jamied's Avatar
yea i just popped the clutch
what should i adjust my tire pressure to?
Old Mar 6, 2006 | 10:35 AM
_Keith_'s Avatar
Whats ur tire pressure? Stock?
Old Mar 6, 2006 | 10:43 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civexturbo &raquo;</TD></TR><TR><TD CLASS="quote">2.5 isn't real great for a 60' time. Drag radials will get you around a 2.2-2.0. Wheel hop is also a killer, try adjusting your tire pressure to help a little bit.</TD></TR></TABLE>
lol you can get 2.0 on street tires if your good...
Old Mar 6, 2006 | 11:18 AM
Jamied's Avatar
no idea what my tire pressure is stock..i just know its got the stock wheels and the tires are in new condition (pirelli's)
im trying to be "good" so plese tell me how i can get my 60' lower
Old Mar 6, 2006 | 12:29 PM
alleyezonme's Avatar
let air out of your tires, did you do anything to lessen your weight?
Old Mar 6, 2006 | 12:48 PM
Jamied's Avatar
how much psi should i let out?
i took out my spare
Old Mar 6, 2006 | 01:03 PM
siregcivic's Avatar
when i race i have my tire psi at about 21-23 depending on how cold it is.. i launch at like 4k.. but i slip the clutch out. and get 2.2 2.1 60 ft's.. if u pop the clutch.. like just release it fast.. you are going to get mad wheel hop or wheel spin.. try to keep the tires from spinning.. your not just going to be good at it.. it takes practice
ive been racing for 5 years.. not all at the track either just lately have i been going to the track.. if you practice alot.. i street raced alot.. and i do not suggest doing that.. but practice at the track.. you will get good.. i got my 92 cx with a single cam vtec stock with b16 ecu to hit a 15.15 in the quarter and a 9.66 in the eigth..
you will get good.. dont drop the clutch.. ride it out in first gear just a little ull get it dont worry
Old Mar 6, 2006 | 01:41 PM
Jamied's Avatar
yea i think im going to go again this weekend and see what i can do
another question is, what should i do performance wise next? i was thinking skunk2 intake manifold and a bigger TB, how much u think thatll give me?
thanks for the help guys
Old Mar 6, 2006 | 02:03 PM
NesaiTuner's Avatar
If your really trying to get power don't worry about T.B or I.M worry about buildin internals...if you don't have the money for that then what you had in mind would be fine...also you might want to consider either chiping or geting your ecu tuned...no matter what you put on your car it's still gonna be running the stock program..when you change things on your car your afr is going to need to be changed...just a thought. also for your launch, i only drove my friends 3 times down the track. launch around 3700-3900rmp...street tires...lower your pressure to 25-27psi. you also might want to consider a traction bar. Good luck with it
dclsvtec
Jun 1, 2004 03:10 PM
STREETWERKZ
Apr 25, 2004 11:43 PM
capcon83
Sep 12, 2003 10:15 AM
