well another swap, ran for a while, now no start, h22
buddy of mine swapped a h22 into his 95 4 d00r and had it running. no it keeps bloing acg fuses(fuel pump) im guessing wiring on the injectors. hat else blows fuel pump fuses?
The fuel pump is driven off the main relay and even though the injector ground is also controlled via the main relay, its a seperate circuit. I would check the pump first to make sure its not siezed/dead.
