Water where my spare was
Does n e one or has n e one had this problem, after it rains, or i go through the car wash, water always happens 2 get into where my spare tire used 2 be, has n e one had this problem, if so how can i fix it??? TIA
I had the same problem on my 'teg. The easiest thing to do is to drill a small hole in the frame under the spare. It won't hurt the car and water will drain right out.
check the seals on your tail lights. mine were bad and where leaking. if you check them make sure you torque the nuts back on in the right order.
EDIT: BTW, why would you pay and go through a car-wash? They're not good for the car.
[Modified by Calavera, 7:05 PM 3/30/2002]
sorry took so long to reply. when i resealed mine i used 3m strip caulk. when puttin the nuts on use a crisscross pattern...do 1 then the oposite on the furthest end.
everyone says taillights gasket seals, and that is the most likely cause of water in your trunk in tegs. check the seals; if they look worn, have em replaced. but be aware it could be a number of other things. like a drain tube or as a result from a previous collision damage
you could also strip your trunk ..hang out inside while you have a friend spray your car down with a hose
I have the same problem. My tail lights leak. also, my rear passenger side window isn't sealed properly. I just put some clear silicon sealant around it for now. looks like **** but keeps my car dry. I was going nuts trying to follow all the leaks in my car, it is a pain in the ***, huh?
I have the same problem, but cant find the leak. I dont think it is the tailights, because the water trails to the spare. I wonder if it could leak in from the side or what not? Hmmm..
[Modified by ilsoc, 5:28 PM 4/9/2002]
Wow that is alot of water. Have you taken a look at where the rear frame joins the floor. I noticed that there is actually a gap there and water can get through there but the water in your trunk is alot. I could only see this happening if you drove over a lot of puddles.
Thanks for the info, I will check as soon as it stops raining. This only happens on this level like today, when it is really HEAVY rain. Other than that its a small puddle.
my 98 gsr does it too, but it only started happing after i got rear ended, and they had to replace the left rear quarter panel, and the bumper, it used to leak bad, so i had the fix it, but its doing it again cause i noticed it today, mine was the seal between the quarter panel and the bumper check that, or after i get mine fixed again ill let you guys know what it was.
Does it only happen when you drive in the rain? Or, does it also happen when you let it sit out in the pouring rain?
JDubya
Jun 3, 2003 09:42 AM
