Replace flywheel but use same clutch?
Old Mar 5, 2006 | 03:44 PM
aZnjCC's Avatar
Default Replace flywheel but use same clutch?
Is there anything detrimental to just replacing a flywheel with a lightened unit while using the same clutch?
Old Mar 5, 2006 | 04:17 PM
NJIN BUILDR's Avatar
Default Re: Replace flywheel but use same clutch? (aZnjCC)
As long as the disc is still in good shape you will be ok.Most people change the disc and pressure plate because they are ussually worn and don't want to pull the tranny again in the near future.
Glenn
Old Mar 5, 2006 | 07:59 PM
MisterCMK's Avatar
If you are taking the effort to replace the flywheel you might as well throw a new clutch in.
Old Mar 5, 2006 | 08:04 PM
aZnjCC's Avatar
that's what i figured.
My clutch is only a year old, so I'd rather just keep the clutch
Old Mar 6, 2006 | 02:10 AM
StorminMatt's Avatar
Default Re: Replace flywheel but use same clutch? (MisterCMK)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MisterCMK &raquo;</TD></TR><TR><TD CLASS="quote">If you are taking the effort to replace the flywheel you might as well throw a new clutch in. </TD></TR></TABLE>
It all depends on your funding situation. A new clutch kit costs several hundred dollars. And even just a new disk is going to cost over $100. For this reason, I would take a chance on the one I already have (if it looks good) rather than dumping several hundred dollars (that I would rather spend on something else) on a new clutch. Even if I was to get only a year or two out of it, I would consider the risk worthwhile. Replacing a clutch might not be the funnest thing in the world. But it is hardly the end of the world. If, on the other hand, you have money to burn, you might as well upgrade your clutch.
Old Mar 6, 2006 | 07:09 AM
aZnjCC's Avatar
replacing Just the flywheel is ALOT simpler than replacing the clutch I presume?
EDWINV00SI
24
Oct 13, 2011 06:08 PM
friscorep
Dec 19, 2006 06:56 PM
allmotor99lude
Jul 7, 2005 08:01 PM
civicracer99
Aug 25, 2003 01:32 PM
matht27
Jul 16, 2002 04:34 AM
