D15B SOHC VTEC p28 ECU
you are looking for a p08 ecu. the differance is the P28 from the usdm civic si/ex uses a 4 wire o2 sensor, and the p08 jdm D15b ecu uses a 1 wire, they are interchangeable, depending on which type of o2 setup you run. hope that helps widen your search for an ecu.
^ yes sir, i know, I am currently using the stock D15B7 wire harness and 4 wire o2 sensor on my D15B vtec. so p28 is for me.
bump. I can use an automatic VTEC ecu as well.
showbowt
Mar 19, 2008 03:06 PM
no_rice_please
Feb 25, 2007 07:29 PM
darkmarc
Aug 20, 2004 09:45 AM
4gvtec
10
Feb 28, 2002 06:01 PM
