Is this setup stock?
Old Mar 5, 2006 | 02:08 PM
De_tour's Avatar
Default Is this setup stock?
Modified by De_tour at 6:38 AM 8/30/2008
Old Mar 5, 2006 | 02:09 PM
De_tour's Avatar
Default Re: Is this setup stock? (wspcivic)
Old Mar 5, 2006 | 02:10 PM
Brodie Bruce's Avatar
haha, yeah thats stock
Old Mar 5, 2006 | 02:11 PM
hondachris1994's Avatar
I believe it is stock because I have a b16 and it says the same thing
Old Mar 5, 2006 | 02:16 PM
De_tour's Avatar
Default Re: Is this setup stock? (hondachris1994)
Modified by De_tour at 6:39 AM 8/30/2008
Old Mar 5, 2006 | 03:33 PM
SkoundrelUSA's Avatar
cute little bastard
My ITR TB has the Had on it so...
Old Mar 5, 2006 | 03:34 PM
743power's Avatar
Default Re: Is this setup stock? (SkoundrelUSA)
stock, clean looking motor though.
Old Mar 5, 2006 | 03:36 PM
ABK's Avatar
ABK
Default Re: Is this setup stock? (743power)
looks like somebody put new bolts and gaskets in it. Everything is so shinny and nice.
Old Mar 5, 2006 | 04:43 PM
De_tour's Avatar
Default Re: Is this setup stock? (ABK)
Old Mar 5, 2006 | 04:55 PM
ABK's Avatar
ABK
get AEBS matifold it's pretty cheap and just as good if not better as skunk2 or blox. Try to get a hold of ITR TB, or just bore yours out.
What kind of header are you running. Get an Ebay ITR intake 3" version.
The gains will be ait, prolly like 10whp. If you want more gains. Well you got two options turbo, or built motor. LS motors on crower 404s make some good numbers.
Old Mar 5, 2006 | 05:00 PM
De_tour's Avatar
Modified by De_tour at 6:42 AM 8/30/2008
Old Mar 5, 2006 | 05:22 PM
De_tour's Avatar
bump
Old Mar 5, 2006 | 05:32 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">dc 4-1 headers
will the 404's affect the compression enough where it would be more then what the head was made for?</TD></TR></TABLE>
dc sucks
might wonna think about a more expensive header. If you plan on running 404s I suggest you raise the compresion up, so you might as well rebuild the motor.
Old Mar 5, 2006 | 05:34 PM
De_tour's Avatar
Old Mar 5, 2006 | 05:36 PM
De_tour's Avatar
Old Mar 5, 2006 | 05:47 PM
ABK's Avatar
ABK
403s should be okay, but you need valvesprings still.
you could technicaly run 404s if you take of the head and mill the **** out of it, and run a 2 layer headgasket. You got to add the cost of tunning too. Either way you will have to shell out good amount of money.
Old Mar 5, 2006 | 05:53 PM
De_tour's Avatar
Old Mar 5, 2006 | 06:15 PM
ABK's Avatar
ABK
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wspcivic &raquo;</TD></TR><TR><TD CLASS="quote">well i like what i have right now for a setup, its enough power for being a daily driver and it gets 44mpg.
if i could get 25-50hp more id be happy or even just keep the power i have now and try to acheive better gas mileage then what im already getting.
i wrote down the ITR manifold, what about throttle body and headers of choice?</TD></TR></TABLE>
I don't think that ITR matifold fits. get AEBS matifold.
ITR TB might good.
For the header I would choose something out of sparks, AN-R, RMF, rage and so on. Nothing cheap.
I dought you will get 25whp out of all of this without some internal work. Nonvtec cam upgrade will prolly hurt you gas milage pretty good due to the fact that you get pretty irretic idle.
Old Mar 5, 2006 | 06:19 PM
De_tour's Avatar
Modified by De_tour at 6:43 AM 8/30/2008
ej1252
Jan 18, 2010 03:06 PM
honda305
Mar 18, 2009 07:24 PM
86si
21
Jun 12, 2007 02:44 AM
jaydmcrx
Sep 28, 2005 10:07 AM
yellowredR
16
Aug 15, 2003 11:23 AM
