IF YOU HAVE DONE THIS PLEASE REPLY
Old Mar 30, 2002 | 04:05 PM
got rice's Avatar
Default IF YOU HAVE DONE THIS PLEASE REPLY
IF YOU HAVE DONE A 99-00 SI SWAP INTO A 96 CX PLEASE HELP I NEED ALL DETAILS THAT I CAN GET
FOR THE GUYS THAT HELPED ME EARLIER THANX
GOT RICE!
Old Mar 30, 2002 | 04:18 PM
fowler!'s Avatar
Default Re: IF YOU HAVE DONE THIS PLEASE REPLY (got rice)
what do you need to know?
Old Mar 30, 2002 | 04:20 PM
fowler!'s Avatar
1. You need a 96-98 Ex harness. A 2000 Si WILL NOT work.
2. You need an OBD II (96-98) ecu (ITR or Del Sol)...
if you plan on using another ecu, you need to purchase an adapter harness from JDMhondaparts.com or Skunk2 and the ecu that you want (usually a chipped p28 will do the trick).
Old Mar 30, 2002 | 08:23 PM
B18C-EJ1
Guest
Posts: n/a
Default Re: IF YOU HAVE DONE THIS PLEASE REPLY (fowler)
Craig, how come the 99-2k SI harness won't work?
Kamin's Avatar
i didnt think there was an obdII del sol ecu.
i could be wrong tho.
but yes. new ecu
[Modified by KAMiN, 9:23 PM 3/30/2002]
Old Mar 30, 2002 | 10:08 PM
HXMan's Avatar
Default Re: IF YOU HAVE DONE THIS PLEASE REPLY (B18C-EJ1)
Different ECU connector to the chassis...its the green one in the passanger compartment by the ECU. I tried to think of a way to get it to work, but I couldn't.
Old Mar 30, 2002 | 11:56 PM
CivicEK.PDX's Avatar
Default Re: IF YOU HAVE DONE THIS PLEASE REPLY (HXMan)
I used a 00 Si harness . But that is because I am just good like that
Actually he is right.....The way I was able to use that harness was I converted my 96 CX to 00 Si specs.....ie: the dash and all interior wiring. Kind of cool cause now I have a CX hatch that reminds me (cause it is the same parts ) as my old 00 Si
Your easiest way would be 96-98 EX wire harness and a 96 Delsol DOHC brain or a jumper harness with DOCH program.
Old Mar 31, 2002 | 06:16 AM
fowler!'s Avatar
Read my story on my site, I know from way too much experience.
Old Mar 31, 2002 | 06:27 AM
fowler!'s Avatar
Default Re: IF YOU HAVE DONE THIS PLEASE REPLY (KAMiN)
Yeah, I think that there was like one or two years where the Del Sol had an OBD II ecu. My friend runs that computer in his 96-98 EK.
Those things are worth their weight in gold. Any P30 or OBD 1 P72 is worth like 3 bills.
Old Mar 31, 2002 | 10:55 AM
Trey's Avatar
25 Year Member
96-96 del Sol ecus's do exist.....
Here is some swap info that will help, but reiterates what fowler said....
http://www.jspectuning.com/6gen/
HTH
BradEK9
Aug 22, 2013 03:28 PM
smiko0124
Jan 9, 2010 09:34 PM
ixoiiiiviviiivi
12
Mar 27, 2009 12:45 PM
MeanGreenEG9
Dec 6, 2002 06:21 AM
