Need Help With AEM Injector Driver
Old Mar 5, 2006 | 12:17 AM
T Dohc's Avatar
Default Need Help With AEM Injector Driver
I am installing one on my 99 civic si, and i am confused on the wiring. I am removing the honda resistor box that i put on there and installing the Aem, Any help with the wiring would be great
Thanks
Old Mar 5, 2006 | 10:18 AM
T Dohc's Avatar
bump i know some knows how to install this
Old Mar 5, 2006 | 12:11 PM
D-tuned's Avatar
Default Re: (T Dohc)
the injector inputs on the injector driver connect that to the wires for the injectors on the ecu side. the injector output wires on the injector driver goes to one side of the injectors. on the other side of the injectors connect switched 12v to it. connect the 2 red wires on the injector driver to switched 12v and the black wire to ground
Old Mar 8, 2006 | 04:21 PM
T Dohc's Avatar
So i need to remove the resistor box put it back to stock, Then install on the ground side since hondas are ground pulse activated?
Just making sure i install this thing right the first time.
Thanks,
Nick
Stick2swishers
Jul 28, 2009 05:38 PM
DA jeshy
Mar 10, 2006 01:13 PM
Justin Olson
Dec 14, 2005 11:06 PM
ironcheftony
Apr 14, 2005 02:39 PM
BLACKLUDE97
Dec 24, 2003 04:25 AM
