Need Help With AEM Injector Driver
I am installing one on my 99 civic si, and i am confused on the wiring. I am removing the honda resistor box that i put on there and installing the Aem, Any help with the wiring would be great
Thanks
Thanks
the injector inputs on the injector driver connect that to the wires for the injectors on the ecu side. the injector output wires on the injector driver goes to one side of the injectors. on the other side of the injectors connect switched 12v to it. connect the 2 red wires on the injector driver to switched 12v and the black wire to ground
So i need to remove the resistor box put it back to stock, Then install on the ground side since hondas are ground pulse activated?
Just making sure i install this thing right the first time.
Thanks,
Nick
Thanks,
Nick
