TurBO LS
Old Mar 4, 2006 | 11:17 PM
BB2_SI's Avatar
Default TurBO LS
HEY i have a Question. i have a 90 DA with a 95 Dc2 LS motor in it. nothing special. b18b i was planning on throw a Drag turbo on it but wanted to find out some prob i may run up on. And i also wanted to know if i should tune my engine before turbo or after. Oh and my goal for my Da is fun Daily driver. Thanks
Old Mar 5, 2006 | 06:45 AM
crxnj's Avatar
Default Re: TurBO LS (1990_DA)
Drag kit is a good starter kit..I mean you can piece together a better kit for cheaper but do what you want...And you tune the motor after the kit is on but you cant really tune the fmu the drag kit comes with..Fmu and high flow inline pump setup is ok for low boost under 6psi..But if you go past that I recomend getting something like uberdata if you're obd1 or turboedit if you
re still obd0,higher flow injectors and highflow intank fuel pump..
Mr. Softee
Jun 5, 2002 06:56 AM
NickGSR
May 6, 2002 01:36 PM
DragII
Oct 1, 2001 11:43 AM
iluznxpnoi
Jul 7, 2001 02:08 PM
