Engine won't run.
Here is the background.
B18c engine sleeved w/forged internals, stock head, turbo.
I have my fuel set-up and ecu from my previous set-up (b16 turbo).
Ecu hondata chipped p-72
fuel: holley 255lph intank, 756cc injectors, AEM fpr, rest is stock.
I swapped the AIT and evap purge plugs by accident when wiring the motor (plugs are identicle and 3" apart, easy to do)...that fried a resistor in my ecu. I had that repaired and the confirmed the ecu was good using their chip....
I get the ecu back and the same problems..solid cel, and runs super rich....(my garage smells like fuel after less then 2 min of running)....so I figure that it's probably my tune that got screwed up....so I cut jumper j-1 wire my stock inectors back in and the car starts for about 4 seconds and dies.......after that I cant get it to run...
Prior to changing the injectors it would at least run...A couple days later (today)
I changed ecu's and tried it again....same thing, it will fire up the first time and run for a few seconds then die....if it give it any gas it dies instantly.
This has been one problem after another.....any sugestions? thanks for taking the time to read...
Violentpanda
Sep 11, 2018 02:57 PM
so simple
Apr 12, 2009 08:31 PM
