changed thermostat and now heater is not working...
I replaced my old thermostat with a brand new oem one. When I had my old thermostat the heater was working fine. I made sure to plug everything back up. The reason I changed it was because my cluster said I was overheating and my fan was not turing on. Has anyone heard of this? Is it something to do witht the coolant? I searched a lot of topics but didn't find anything after replacing the thermostat on **** not working Thanks.
Modified by alphanumeric at 4:18 PM 3/4/2006
did you put it in backwards? (It has happened)
Did you make sure to fully bleed it and that there are not air pockets?
Did you get the right thermostant (OEM or correct temperature)?
An overheating car and a fan not turning on is usually an indication of a faulty fan relay switch, not a thermostat.
Blaze45
Mar 8, 2018 02:57 PM
tianporn
Jul 29, 2005 11:44 PM
stealth civic
Jan 13, 2005 09:03 AM
