stainless steel header
ok so i hear that when you install a stainless header its best not to leave finger print on it b4 starting because they will get baked in. is this true? and also give me any tips i should know for this.
tia
tia
hey just installed one tonight. wipe it down w/ brake cleaner or paint thinner or some sort of solvent that gets all the oil residue off before running. i personally use an old biker trick to help it from blueing, spray the inside of the runners w/ high temp paint as best as possible before installing it. there is also companies that make an anti blueing product as well
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by panovel »</TD></TR><TR><TD CLASS="quote">hey just installed one tonight. wipe it down w/ brake cleaner or paint thinner or some sort of solvent that gets all the oil residue off before running. i personally use an old biker trick to help it from blueing, spray the inside of the runners w/ high temp paint as best as possible before installing it. there is also companies that make an anti blueing product as well</TD></TR></TABLE>
what he said... you can touch all you want just make sure you wipe it down afterwards
I had one for a while, It was blueish bronze color. As it got farther away from the head, it got lighter. I would say about the first 6 inches of the header changed colors. After that it stayed the original stainless steel color.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jomama »</TD></TR><TR><TD CLASS="quote">can you wipe it down after the prints/bluish stuff has been "baked" on?</TD></TR></TABLE>
do a lil sanding ,
jus gotta repolish it
do a lil sanding ,
Bond
10
Sep 5, 2005 09:15 PM
jimmhatch
Sep 25, 2004 08:43 AM
