Painting header?
Painting header?
my header is pretty old and grose looking/dirty... its a DC 4-2-1, i want to paint it... i tried using regular high-temp paint from walmart but it just turned to powder after one day... is there a higher-tolerance hightemp paint available or should i just wrap it up with heatwrap?
Darth ModerVader
Re: Painting header? (Kalokohan)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kalokohan »</TD></TR><TR><TD CLASS="quote">check out VHT products, they have very good high heat temp. products but like Archidictus said, jet coating would prolly be best.</TD></TR></TABLE>
I believe that's what my brother used on his DC JDM 4-1 (it may have been something similar though). Even after following the directions thoroughly, and curing the paint, it flaked off in a matter of days.
Unceasing Measure
Re: Painting header? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">what is jet-hot coating? and powdercoating costs $$, i want a DIY job.</TD></TR></TABLE>
Jet Hot is a thermal barrier that is applied to the inside and outside of your header or intake or whatever you send them. Not only does it look incredible and last forever, but it doesn't crack under impact, increases airflow, reduces underhood temperatures and increases the life of your header.
It's expensive, but it's worth it.
jimmhatch
09-25-2004 08:43 AM
JDMlyfestyle
07-20-2004 02:30 PM
