HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS*
Old Mar 3, 2006 | 12:16 PM
PINKS's Avatar
I want a CRX tattoed on my butt
Default HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS*
Well heres my story
Ive got an 88 Crx si, d16a6 motor. I recently had a ramhorn manifold but I got rid of it because I became broke, I got this eg rad to work fine with the ramhorn because the wastegate was facing forwards.
now my new manifold places the wastegate to the side and the rad just wont fit anymore, I have to tilt it back and the hood will not close alllllll the way and I dont even have a rad cap on it yet
The first time around I cut the stock crossmember up a bit and wedged the rad down there *the crossmember was welded up where I cut, not shown in pic*
But now I need to pull the rad back a good inch and drop it down another inch, in order to do this I need to cut the bar infront of the crossmember, I think its called the rad support but I duno, see pics
Am I allowed to cut this notch out of this bar without reinforcing it or is it a structural part of the car?
Old Mar 3, 2006 | 12:17 PM
youtouchmytralala's Avatar
Default Re: HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS* (TurblowEF)
it's semi-structual.
cut some of the webbing out of the top of the hood. done deal.
Old Mar 3, 2006 | 12:27 PM
jlicrx's Avatar
Default Re: HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS* (youtouchmytralala)
we cut the lower radiator support bar completely out of ours and made brackets off the crossmember lip to support our EK radiator - it is just there as its name implies as a radiator support
Old Mar 3, 2006 | 12:39 PM
PINKS's Avatar
Default Re: HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS* (jlicrx)
So its not structural? I dont mind cutting it off one bit
i was hesitant though and just got busy with other ****
heres another pic of what the rad looks like before
Oh and the webbing is cut out of the hood, but its a fiberglass hood, seems to sit lower
Old Mar 3, 2006 | 02:48 PM
PINKS's Avatar
Old Mar 3, 2006 | 03:00 PM
D15B2civic's Avatar
i used a grinder to cut half of the old radiator support to fit a 97 radiator in..
Old Mar 3, 2006 | 04:33 PM
speeddave's Avatar
Default Re: HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS* (D15B2civic)
i cut mine there too, i cut mine closer to the pass. side headlight, so it sits flat against the top support. makes it look a bit cleaner.
Old Mar 3, 2006 | 04:50 PM
PINKS's Avatar
Default Re: HACKING!! Eg 1/2 Rad Install - Stock Crossmember - Can I Hack This? *PICS* (speeddave)
Awesome, thanks guys I didn tknow I could do it like that or not, aparently I can
Sparks will be flyin tomorrow
Old Mar 3, 2006 | 05:41 PM
UltimX's Avatar
tilt.... cutting the x member will weakin it. do the tilt.
Old Mar 3, 2006 | 07:01 PM
beyondspexj's Avatar
yup just tilt. few people have cut crossmembers only to jack up the car one day and see it either cracking or already cracked and no good for anything anymore.
Old Mar 3, 2006 | 09:11 PM
PINKS's Avatar
Default Re: (beyondspecs_jamar)
Thats not a crossmember thats being hacked, i cut off the lip on mine and welded the seam back together, but with this new setup it isnt enough, I need to cut the rad support out prety much and fab some bracketery I guess
Tilting makes your car look thrown together to me, id rather hack it haha
Old Mar 4, 2006 | 12:45 AM
my fault. now with cutting the radiator support does that weaken the front end any? like letting the body flex in the front??
Old Mar 4, 2006 | 05:00 PM
UltimX's Avatar
i'm just letting u know what happens. good luck bro! it does weakin the x member and eventually tweak the front end. it all depends on how u drive.
Old Mar 4, 2006 | 05:02 PM
PINKS's Avatar
Default Re: (UltimX)
I drive like a **********, constantly dropping gears and launching
I might throw a brace across it infront of the rad, i might not need to completely cut it out, just a good 1" chunk of it
Girl was in the hospital today, couldnt do ****
Old Mar 4, 2006 | 06:44 PM
HondaCivicSiR1's Avatar
Default Re: (TurblowEF)
i just recently did this for my custom traction bars (made by dturbocivic)and my eg radiator i post some pics tommorrow
Old Mar 4, 2006 | 10:28 PM
Blaze45's Avatar
Brrraaaap!
Default Re: (HondaCivicSiR1)
I did what D15B did, cut that front brace off, and I relocated the cooling fan to a pusher fan, well upgraded to a 1400cfm pusher. Now I have plenty of room for a filter on my turbo.
Old Mar 5, 2006 | 01:44 AM
ex voto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TurblowEF &raquo;</TD></TR><TR><TD CLASS="quote">I drive like a **********, constantly dropping gears and launching</TD></TR></TABLE>
I just wanted to say that I loved that line.
Old Mar 5, 2006 | 03:15 AM
PINKS's Avatar
Default Re: (ex voto)
Its true though, leaving now to go hack that bastard, I'll take a few pics
Old Mar 5, 2006 | 12:44 PM
PINKS's Avatar
Well it was pretty easy, took 5 min to cut it off and then I cut a piece of 2 inch high 1/4" thick mild steel and welded it across the bottom, so my rad sits on that and it ziptied to it and my intercooler is also attached to it
Turned out pretty nice actually
I'll take a pic tomorrow
highroller54
Jun 22, 2010 07:16 AM
sasinorm01
Jul 22, 2009 07:49 AM
mrbsponge
Aug 20, 2008 07:06 PM
AnitRiceSuperStar
Mar 13, 2004 12:13 AM
