maintenance light?
On the guage cluster there is that little light which can be green or red. Beside it, it says "maintenance required".
my question is.....what does this light indicate and what color should it be when everything is alright?
mine has been red since i bought it(never thought anything of it) and just yesterday it turned green.
thnx
thnx
What car are you referring to?
The Maintenance Required light indicates that it may be time for service such as an oil change. Check your owner's manual on how to reset it.
on 5th gen cars the color will remain green for 6K and turn yellow after that. Once it reaches 7.5K. It turns red.
Basically it reminds you to change your oil and do a visaul inspection of your car. Every other time it changes to RED, it's time for some other things to be inspected and repaired or replaced as needed.
To reset the 5th gen there is a button to the right of the indicator that you insert the key into and it resets.
On the 6th gen car, hold the trip odo reset button, turn the ignition on and after 2 seconds release the trip odo button.
MaD3 In JaPaN
Jan 27, 2018 11:56 AM
