knock sensor problem
Old Mar 3, 2006 | 06:51 AM
petarr's Avatar
Default knock sensor problem
my knock sensor is wired up, but when i drive for about 5 mins the cel comes on. if i turn off the car and turn it on again it goes away until i drive another 5 mins. it says the code is the knock sensor, but even when the cel is on, the vtec still kicks in. any idea?
Old Mar 3, 2006 | 12:59 PM
scmil95eg's Avatar
Default Re: knock sensor problem (pthevanh)
had the same issue. are you running premium gas?
Old Mar 4, 2006 | 07:32 AM
petarr's Avatar
Default Re: knock sensor problem (gdmfsob069)
yea running 93. if my mph's stay below 50 the cel won't come on. i tried grounding the knock sensor wire, still no help.
Old Mar 4, 2006 | 10:37 AM
MrMike's Avatar
make sure its hooked up correctly. get a voltmeter and check for continuity from the connector plug to the ecu pin D3 for obd1. If its wired correctly then try another knock sensor.
VTECth1s
Aug 20, 2006 02:16 PM
b18cEF9
Dec 20, 2004 04:22 PM
memphiss13
Jul 1, 2002 04:05 PM
