question for ITR DC2 guys with OBD-I swap
Old Mar 3, 2006 | 02:37 AM
dark-b16a1's Avatar
Default question for ITR DC2 guys with OBD-I swap
Guys, I'm in a big need of a fuel&ignition map downloaded from stock ITR P73 ECU(Euro version at best), so I can implement these values into OBDI P28 or P30 ECU(didn't buy yet).
Does anyone have these maps?
Old Mar 3, 2006 | 02:45 AM
Asahi's Avatar
Default Re: question for ITR DC2 guys with OBD-I swap (dark-b16a1)
A P28 Map will run the car fine until you can get it tuned. Why not use Hondata?
Old Mar 3, 2006 | 04:18 AM
s2kdre's Avatar
Default Re: question for ITR DC2 guys with OBD-I swap (Asahi)
im using a jdm p73 obd2 and i love it cause it has no 2nd o2 reading and no crank angle sensor non of that bs like the usa ecu.
Old Mar 3, 2006 | 04:42 AM
dark-b16a1's Avatar
Default Re: question for ITR DC2 guys with OBD-I swap (jdmhonda)
Hondata does not support directly P73 european version with th S200 kit(at least from what I know), and the fully programable ECU costs a fortune
I need the OBD-I swap beause I'm going to install Buddy Club Specs III+ cams, so I need to add more fuel.
Also, I belive that the P28 has far different ignition from the stock ITR, and I don't believe anyone is able to tune ignition so precisely like the ITR stock setting.
I have Crome for OBD-I tuning, that's why I want OBD-I.
Old Mar 5, 2006 | 01:25 AM
dark-b16a1's Avatar
sunday morning bump
Old Mar 5, 2006 | 06:34 AM
an2ny888's Avatar
i've also been looking for that map, sadly it's very hard to find.
Old Mar 5, 2006 | 09:32 AM
92TypeR's Avatar
FSAE
Default Re: question for ITR DC2 guys with OBD-I swap (an2ny888)
I was running this map for about 6 months before going 2.0L. It was a very quick road tune, but is better than anything I found on the net. (was made in using Crome).
http://www.itrspec.com/BIN/ITRbase.bin
Old Mar 5, 2006 | 10:59 PM
dark-b16a1's Avatar
Default Re: question for ITR DC2 guys with OBD-I swap (92TypeR)
Thanx a lot, I really appreciate that, I'll have a look at the map ASAP.
If anyone else has the raw P73 Euro Integra Type-R basemap that can be viewed by any ROM editor( so I can read the values), please let me know!
Old Mar 6, 2006 | 03:21 AM
Root79's Avatar
Uhhh! Finally!
Are not too advanced ignition?
boosted95si
Engine Management and Tuning
Feb 6, 2011 04:47 PM
mingbling
Feb 27, 2004 10:46 AM
BikeSpike
Dec 29, 2003 07:47 PM
mattL
Aug 1, 2002 12:40 PM
SCsol
May 21, 2002 02:47 PM
