HElp with b18b zex nitrous!!!! everything installed but cars bog/hesitate/stumble
i got everything installed correctly i assume. obd1 LS engine with a zex wet nitrous kit. greddy header, aem intake, and tanabe exhaust with 2 1/4 piping. my timing is at 16. the nitrous bottle lines are installed correct and i T the fuel off the fuel rail lines. its a 55 shot jet. activation only WOT.
everytime its a WOT when it shot, the car hesitate/stumble/bog and dont even go anywhere then after a few secs it goes. i know thats not normal at all.
need some help??????
ur timing is way to high, and do u have colder plugs? are they gapped right? i would bring that timing down to 12-13 degrees cause it aint worth putting a hole in the piston.
damnnnnn. thanks alot. i was assuming it was detonating. cant believe i ****** hold the gas for more than 3-5 secs even when i know its detonating.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tannerLSt »</TD></TR><TR><TD CLASS="quote">yeah don't live up to your name and ignite your civic</TD></TR></TABLE>
hahahahah
damn i found out wat is the problem. the jet for the fuel was .036 and isnt it suppose to be .017 for a 55 wet shot
4 CYL FUEL / N20
55hp 17 / 32
wat jets size for 55 shots? .017/.032???
hahahahah
4 CYL FUEL / N20
55hp 17 / 32
