Bends on a manifold
Old Mar 2, 2006 | 09:37 PM
vr6chris's Avatar
Default Bends on a manifold
OK, I am about to start mock up on my first manifold. I am using sch40 mild steel pipe. I have a bunch of 90's and a few feet of straight pipe. For doing some small bends, what should I do make those? Cut the straight pipe at an angle with my chop saw or what? I know i could cut the 90's if i had a bandsaw, but what should I do? With my chop saw, the 90 bend won't stay clamped to cut at a 45 degree angle. Just buy some 45's? Thanks for the help
Modified by vr6chris at 12:13 PM 3/3/2006
Old Mar 3, 2006 | 10:12 AM
80884's Avatar
Default Re: Bends on a manifold (vr6chris)
Start with plastic pvc pipe, easy to cut, same thing as the metal but easier to cut and work with till you get the angles figured out. Plus you can melt it together.
If your having a hard time cutting 90's and don't have the set up to do it, it will be a pain in the butt to do.
Could also try holding the 90 to the plate on the chop saw with some vice grips or welding clamps...
Old Mar 3, 2006 | 10:20 AM
jon volk's Avatar
Default Re: Bends on a manifold (80884)
Ive cut 90*'s with a chopsaw back in the day by holding it by hand with an old welding glove. It wasnt fun but it worked.
Bandsaws own
Old Mar 3, 2006 | 10:50 AM
vr6chris's Avatar
Default Re: Bends on a manifold (k20 jon)
i might just try and make a jig or something. rather not lose a finger.
Old Mar 3, 2006 | 11:19 AM
80884's Avatar
This isn't exactly a 90 mounted but thats how to do it and be somewhat safe.
Dunc
Dec 21, 2015 12:01 PM
TurboSI56
Welding / Fabrication
Feb 20, 2007 04:33 PM
integrawhat
Feb 9, 2006 12:04 AM
UnnaturalAspirations
Apr 17, 2005 08:40 PM
Turbo-charged
41
Nov 30, 2004 04:19 AM
