trouble putting my car in 1st and 2nd gear...
Old Mar 2, 2006 | 08:56 AM
smooz EK's Avatar
Default trouble putting my car in 1st and 2nd gear...
i just got my 96 dx hatchback from the shop. i replaced the tranny, clutch, and fly wheel.
i was pretty excited to get my car back so i could see how it feels, but ended up being pretty disappointed after i drove it home. they replaced my clutch with a SUPER LIGHT, SOFT clutch, which i hate. hopefully i get used to it so it doesn't bother me that me that much. i also noticed that i have to almost force it in to 1st, 2nd, and reverse, sometimes. i'm not sure why this is happening because before i replaced everything, all the gears went in smoothly. can anyone help me out?
Old Mar 2, 2006 | 09:21 AM
TurboSI24's Avatar
Default Re: trouble putting my car in 1st and 2nd gear... (smooz EK)
have you checked you master and slave cylinder?
Old Mar 2, 2006 | 10:56 AM
snatch's Avatar
Is it easier to shift it through the gears with the car not running?
Old Mar 2, 2006 | 11:15 AM
DJ_Toocrazy's Avatar
i have a friend who has a ek with a light weightfly wheel, new tranny, and a act stage 3 clutch, i tried driving his car and it was pretty difficult for me, i had to rev it to around 3.5k rpm just to get going in first gear maybe you have the same situation? if not then i couldnt be much help from here on sorry
Old Mar 2, 2006 | 11:19 AM
tsdenny's Avatar
Default Re: trouble putting my car in 1st and 2nd gear... (DJ_Toocrazy)
chech the cylinders.
make sure there is no leak.
Old Mar 2, 2006 | 11:32 AM
aemciv's Avatar
the clutch may not be properly bled. How does the clutch feel? Can you feel it engauging up top or toward the end of the travel. If it is near the end of the travel it needs to be rebled. Might be air in the line.
prose
Old Mar 2, 2006 | 11:39 AM
sol2hatch's Avatar
yep, make sure the system is bled, sounds like that is it
Also, isnt there a way that you can adjust your clutch? Maybe that is something to look into
Old Mar 2, 2006 | 12:09 PM
HXvtec's Avatar
Default Re: (aemciv)
check the fluid
Old Mar 2, 2006 | 12:17 PM
HXvtec's Avatar
check the fluid make sure they filled the tranny. also as someone said before the clutch is probably not bled which could also be the issue as well.
BILLisCHILL
Jun 21, 2010 07:48 PM
J's91Teg
Oct 26, 2007 11:17 AM
The Weather Man
Jul 3, 2006 08:30 AM
Nicaraguense13
Feb 28, 2006 08:27 AM
DefiantGSR
Jan 30, 2003 09:34 AM
