Radiator Support
Old Mar 2, 2006 | 08:55 AM
GSR_96814's Avatar
Default Radiator Support
I bent my radiator support and I have a replacement on the side. How hard is it to take off the old one and weld the new one back on? Any recommendations my friend is going to try help me do it this weekend.
Old Mar 2, 2006 | 10:22 AM
HybridKOOP's Avatar
Default Re: Radiator Support (GSR_96814)
Not hard, just get a spot weld remover drill bit and go to down anywhere you see spot welds. Make sure the rest of the unibody is straight, then simply weld the new one in place.
Old Mar 2, 2006 | 11:48 AM
hAILO's Avatar
Default Re: Radiator Support (HybridKOOP)
HybridKOOP
Re: Radiator Support (GSR_96814) 11:22 AM 3/2/2006
how exactly do you do that?
Old Mar 4, 2006 | 07:56 PM
guymosiris's Avatar
Default Re: Radiator Support (hAILO)
I'm assuming you have a GSR. Same **** happened to me. You should buy a spot weld bit off ebay for like $25 shipped. I couldnt find one anywhere else. A drill bit for metal will take you all day. This shows you exactly where the spot welds that need to be drilled out are. Good luck https://honda-tech.com/zerothread?id=1346217
SQ is the SQUAD
Welding / Fabrication
Jul 8, 2008 07:44 AM
dubsolo
10
Feb 17, 2008 06:50 AM
1fastVX
19
Jun 28, 2005 02:55 PM
drunknmunkypow
Aug 10, 2003 07:40 AM
