i'm confussed about my del sol
ok, i want to know what the car started out as. i bought the car 9 months ago, last weekend i discovered that it is sohc vtec d16z6, it has non-vtec value cover, P08 ECU not chiped i took the cover off, can not see anything, my dash read 6500 redline, i thought that sohc vtec read 7000.
So was my car non-vtec then someone changed the engine?
Or is my car vtec and someone changed the value cover, ECU, and gauges?
my engine harness look complet vtec wires look stock. i don't know how i would tell what the car had to begin with, i'm going to get the right ecu get the vtec working, i just wonder what happened
i think that some one just put a 93 d16z6 because that valve cover does not say vtec. but the computer is supposed to be a p28. a 6500 redline is from a del sol s maybe this link will help you http://www.teamdelsol.com/technical/faq/
check your vin # after its says JHM if it says
EG1 = s
EH6 = si
EG2 = vtec
EG1 = s
EH6 = si
EG2 = vtec
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by king74738 »</TD></TR><TR><TD CLASS="quote">I think personaly you got freakin screwed</TD></TR></TABLE>
how so ? what if he bought the car for 10 bucks ?
my car is a 93, i only paid 2000 so i dont think i got screwed, what would i look for in my vin number? i can look at my vin but is still dont know how to ID, the wires from the vtec silnode to the ECU the wires or in the sub harness,is a P08 ECU a non-vtec del sol ECU?
Guest
Posts: n/a
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">ok, i want to know what the car started out as. i bought the car 9 months ago, last weekend i discovered that it is sohc vtec d16z6, it has non-vtec value cover, P08 ECU not chiped i took the cover off, can not see anything, my dash read 6500 redline, i thought that sohc vtec read 7000.
my engine harness look complet vtec wires look stock. i don't know how i would tell what the car had to begin with, i'm going to get the right ecu get the vtec working, i just wonder what happened</TD></TR></TABLE>
i think someone changed the cluster n if u have rear disk brakes ur car is an SI model
93 Si didn't come with a valve cover that says VTEC.
Even the del Sol S has a 7k redline. Check the engine and look at the engine stamp on the block. to the left of the header, right by the transmission.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by k20rex »</TD></TR><TR><TD CLASS="quote">is a P08 ECU a non-vtec del sol ECU?</TD></TR></TABLE>
P08 is a jdm d15b vtec ecu. A vtec ecu on a non vtec equipped car should throw cel 22 and rev limit at the vtec crossover point (5500 on the p08) - this is all from my experience with trying this, by the way.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by teazerkuhz »</TD></TR><TR><TD CLASS="quote">i think someone changed the cluster n if u have rear disk brakes ur car is an SI model</TD></TR></TABLE>1993 Si models had rear drums...well mine did at least =P
aln2590
26
Mar 29, 2007 03:33 AM
B18Redline
17
Oct 4, 2006 02:08 PM
Sterling
12
Jul 17, 2002 06:12 AM
Xyster
Jun 9, 2002 07:43 PM
