95 Eg...vtec stopped working...help???
Old Mar 1, 2006 | 07:43 PM
Chicano's Avatar
Default 95 Eg...vtec stopped working...help???
I have a 95 eg with a b16a2...the vtec has worked since the swap was done (a year and a half ago) and recently it stopped working...when its suppose to kick around 6 the check engine light just goes on and will not go off till you shut the car off...I check the sensors under the hood...cleaned them...and nothing...any help would be greatly appreciated
Old Mar 1, 2006 | 07:50 PM
SVOboy's Avatar
What CEL is it throwing? Clean out the solenoid good/try a good one?
Old Mar 1, 2006 | 07:51 PM
shiftgear8000's Avatar
which code is it throwing??? if all is clean maybe the vtec pressure sol. went bad......check the code next time it happens
Old Mar 2, 2006 | 03:05 PM
Chicano's Avatar
Default Re: (shiftgear8000)
I took the solenoid off cleaned the screen and everything around it...still nothing...when I get on it and take it up to high rpm's where vtec should kick the check engine light keeps comming on...if I go hook a diagnostic machine up to it will it fully tell me the correct problem? or anyone have any other suggestions would be appreciated
Old Mar 2, 2006 | 03:11 PM
SVOboy's Avatar
Obd1, right? Just look at the ecu thread sticky at the top of this forum and jump your code.
Micha's Avatar
FAILWGN
Default Re: (skaterguy)
Check the connections to your ecu. I just went through this exact situation and I had to repin some of my wires(all the ones involving vtec) going to the ecu. Good luck.
Dahhhbeed
14
Aug 27, 2016 03:08 PM
PROJECT 91
Jan 26, 2009 06:51 PM
gsrboost737
Aug 7, 2008 06:38 AM
jdm stan
Aug 14, 2005 12:59 PM
miket750
Jan 27, 2005 11:41 PM
