H22 IABs with p28
Old Mar 1, 2006 | 06:11 PM
H22Luda720's Avatar
Default H22 IABs with p28
Im building a boosted h22, im gonna run hondata with a p28, i know this setup will not control the IABs, what are the pros and cons of them not working or just running them open all the time?
Old Mar 1, 2006 | 06:15 PM
The Birdman's Avatar
I think that the s300 can work with the p13 actually... don't quote me on that...
anyways, you can get a p72 (obd1 gsr computer) and be able to keep the functional iab's...
If you stay with the p28 idea, then you would be best off unhooking the vac line that goes to them (which will keep them open all the time)
Old Mar 1, 2006 | 06:32 PM
98vtec's Avatar
moderator emeritus
Default Re: (jd3jdm)
there are ways to mod the p28 to control the iabs.
Old Mar 1, 2006 | 06:54 PM
Default Re: (98vtec)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">there are ways to mod the p28 to control the iabs.</TD></TR></TABLE>
That too.... I remember matt telling me you could do that.... I have never dealt with it personally since I haven't had the stock mani on my car while it had hondata...
Old Mar 1, 2006 | 07:23 PM
CivicSiDriver02's Avatar
I remember seeing a post saying you could use an rpm activated swith to control the iabs. I believe it is in the faq section, ecu thread.
Old Mar 1, 2006 | 08:11 PM
Eddiebx's Avatar
why dont u just hook the iab flapper to a vac port on the IM and call it a day? it will operate close enough to stock.
Old Mar 2, 2006 | 04:37 AM
kulrevon's Avatar
Default Re: (Eddiebx)
or make the p28 control iabs
http://www.pgmfi.org/twiki/bin...ToP28
also I blieve member RMS https://honda-tech.com/zero...06032 can help
fixed link
Modified by kulrevon at 11:46 AM 3/2/2006
Old Mar 2, 2006 | 06:09 AM
iakona's Avatar
Default Re: (kulrevon)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kulrevon &raquo;</TD></TR><TR><TD CLASS="quote">or make the p28 control iabs
also I blieve member RMS https://honda-tech.com/zero...06032 can help</TD></TR></TABLE>
can you post the pgmfi.org link again, that one doesn't work. thanks.
Old Mar 2, 2006 | 06:20 AM
98vtec's Avatar
moderator emeritus
Default Re: (iakona)
Old Mar 2, 2006 | 07:21 AM
IHateJDM's Avatar
what are you building this car for? iab's that are open all the time (vacuum line removed) hurt low end power, but it doesn't affect top end. If you're building the car for drag racing, your best bet is to just remove them from the IM completely. If you are road racing it, you may want the extra low-mid range power from time to time, although its not much of a difference.
Old Mar 2, 2006 | 07:40 AM
vtecspeed1320's Avatar
Shooting Star
how much hurt on low end power ill be running my h22 with a p28 as well.
Old Mar 2, 2006 | 07:48 AM
kulrevon's Avatar
Default Re: (vtecspeed1320)
Old Mar 2, 2006 | 08:47 AM
98vtec's Avatar
moderator emeritus
Default Re: (IHateJDM)
u can tune around the supposed power lose.
Old Mar 2, 2006 | 10:47 AM
H22Luda720's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 98vtec &raquo;</TD></TR><TR><TD CLASS="quote">u can tune around the supposed power lose.</TD></TR></TABLE>
Good point, From what i hear its not much of a power lose, I think im just goona take em out
Old Mar 2, 2006 | 10:50 AM
IHateJDM's Avatar
Default Re: (H22Luda720)
its not a big loss at all. Barely noticable, but you can tell (untuned). I recently pulled them competely out of my IM.
hondaguyef
Apr 15, 2004 04:33 AM
Ddogz15
Apr 15, 2004 12:34 AM
st0nedstoopid
Nov 7, 2003 03:28 PM
CvexH22
Apr 3, 2003 12:01 AM
SilverEk3dr
Mar 24, 2003 11:27 AM
