need help to do my clutch kit!!
Old Mar 1, 2006 | 05:22 PM
crix868's Avatar
Default need help to do my clutch kit!!
i'm plannin on installing a Competition Clutch kit and Flywheel this w/end on my H22 and was wondering if anyone here could help me out on what to do. i have a basic idea on what to do. i did a search and found nothing so if anyone knows where i can search up to a DIY guide or whose willing to help me out. Thanks alot
Old Mar 1, 2006 | 05:39 PM
Saosinx's Avatar
Default Re: need help to do my clutch kit!! (crix868)
well.
make sure you use air lol it makes a big difference obviously.
take off the hood.
pull out everything- batt, intake, anti-freeze resevoir.
jack up the car.
take the plastic guard off from under neath.
take off both front wheels and pull out your axels.
start unbolting everything holding the transmission on.
work the tranny out and drop it.
do the swap.
make sure you lube up the throw out bearing.
make sure you turn the motor manually to make sure it doesn't lock up.
put everything back up.
check your ps resevoir and anti-freeze.
totall time should be 8-12 hours.
here's a link to some of the photos from when i did my clutch install:
https://honda-tech.com/zerothread?id=1509532
goodluck.
someone add anything i missed. i just did this in 60 seconds
Old Mar 1, 2006 | 06:20 PM
jdmlude_dude's Avatar
Default Re: need help to do my clutch kit!! (Saosinx)
buy a helms.
Old Mar 1, 2006 | 06:29 PM
Rudaluda's Avatar
listen keep everything neat!! its easy to get bolts and stuff mixed up.
Old Mar 1, 2006 | 06:48 PM
crix868's Avatar
Default Re: need help to do my clutch kit!! (jdmlude_dude)
my car is a integra wouldn't wanna buy the helms for jus the motor but thanks Saosinx for the help i know when my boy did my kit on my integra it took him like 2 hrs so im hopin to get it done in like 3-4 b/c i do have help also
Old Mar 1, 2006 | 07:07 PM
it took me about 10! good luck on 3-4! Then again it was just me!! LOL
Old Mar 1, 2006 | 07:21 PM
Saosinx's Avatar
i had a second hand and it took a whole day and still some in the morning. i did have a lot more i did. like i had to drive an hour away to get a new clutch slave cylinder. and i spent another hour getting my flywheel resurfaced. without that stuff i would still say it would take 8 hours minimum. i'd give yourself the weekend-on the safeside
Old Mar 1, 2006 | 07:50 PM
quadiv20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crix868 &raquo;</TD></TR><TR><TD CLASS="quote">i'm plannin on installing a Competition Clutch kit and Flywheel this w/end on my H22 and was wondering if anyone here could help me out on what to do. i have a basic idea on what to do. i did a search and found nothing so if anyone knows where i can search up to a DIY guide or whose willing to help me out. Thanks alot</TD></TR></TABLE>
https://honda-tech.com/zerothread?id=907431
Here's the guide I used
-B
Old Mar 2, 2006 | 06:55 AM
crix868's Avatar
Default Re: need help to do my clutch kit!! (quadiv20)
good lookin out quadiv20 cant wait to do my kit this w/end an thank god i dont have to resurface the flywheel, i ended up getting the Competition 11lb for my H22 so lets see how it works when im done will keep u posted thanks alot for the help everyone
Mickstert
Apr 6, 2014 02:44 PM
hondaciv5
Honda Civic (2001 - 2005)
Jul 12, 2007 05:10 AM
churbor
May 21, 2006 06:14 AM
teggytegteg
Oct 4, 2004 07:55 AM
hashpipe623
May 4, 2003 07:45 AM
