vtec question
Old Mar 1, 2006 | 03:14 PM
ezeiset's Avatar
Default vtec question
Hey i have a 94 honda civic with a jdm d15b vtec. i was wandering if there is anyway to check to see if vtec works through the wireing and if yes and u tell me how. thank u
Old Mar 1, 2006 | 03:17 PM
SVOboy's Avatar
Wire up a 12v light to the wire coming from the ecu that controls the vtec solenoid and if it comes on at 5500 or where vtec is set the ecu is activating it. Feeling vtec on a d series is hard (I've never been able too).
Also, which ecu are you using?
Old Mar 1, 2006 | 03:31 PM
ezeiset's Avatar
Default Re: (SVOboy)
stock p28 and we could tell when it kicked cuz it always spun and it threw u back into the seat! but now for some reason its not workin at all
Old Mar 1, 2006 | 03:33 PM
ezeiset's Avatar
Default Re: (ezeiset)
could u explain more about the light?
SVOboy's Avatar
Check the vtec solenoid to see if the screen is clogged, do the light thing, check oil levels/pressure, coolant temp, and speed sensor.
Old Mar 1, 2006 | 03:34 PM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ezeiset &raquo;</TD></TR><TR><TD CLASS="quote">could u explain more about the light?</TD></TR></TABLE>
You splice the light into the wire coming from the ecu and going to the vtec solenoid, if the ecu is activating vtec it will light up.
Old Mar 1, 2006 | 04:07 PM
EG2Driver's Avatar
vtec relies on oil pressure in order to work. If you do not have enough oil, vtec will no engage. It wont engage if the engine is cold. Sounds silly but just make sure those are ok first.
Old Mar 1, 2006 | 04:15 PM
murmur9's Avatar
Default Re: (deadend9009)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by deadend9009 &raquo;</TD></TR><TR><TD CLASS="quote">vtec relies on oil pressure in order to work. If you do not have enough oil, vtec will no engage. It wont engage if the engine is cold. Sounds silly but just make sure those are ok first.</TD></TR></TABLE>
not just on oil pressure my friend
Old Mar 1, 2006 | 04:50 PM
ezeiset's Avatar
Default Re: vtec question (ezeiset)
Ok i also swapped out the d15 harness with a d16. and well there is this sensor on top of the tranny. its kinda round. dont know what it is. it had a plug that plugged right into the harness. and well the 1.6 harness didnt have that so i cut the wires. what sensor is that?it only had to wires
ZLboosted_EG
11
Mar 18, 2006 01:11 PM
Rich93DS
Oct 9, 2005 07:51 PM
SLOAZZ95
Aug 13, 2004 08:31 AM
Nowellfan2003
22
May 27, 2004 03:58 AM
CrazieLude
Mar 4, 2003 11:33 PM
