Camber Kit
Old Mar 1, 2006 | 02:13 PM
defkid999's Avatar
Default Camber Kit
I noticed that the inside of my tire has worn out and my tires stick out like crazy, they have an angle to it...what are the best camber kits to use? i need both front and rear and what brand
Old Mar 1, 2006 | 02:27 PM
postman's Avatar
Default Re: Camber Kit (defkid999)
skunk2 makes a nice one, not all cars can adjust rear camber though, then again there are some ways around that using shims
Old Mar 1, 2006 | 04:09 PM
bmoua's Avatar
i have the skunk2's for my front and works pretty good...i dont have one for the rears but my rears dont wear at all.....
Old Mar 1, 2006 | 04:14 PM
RedEj8's Avatar
Im using front and rear ingalls kit on my 97 civic...i got them off ebay and they work perfectly
Old Mar 1, 2006 | 04:33 PM
DelSolMarine's Avatar
Default Re: Camber Kit (reddohcvtec)
omni camber kit
Old Mar 1, 2006 | 05:10 PM
SVOboy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by defkid999 &raquo;</TD></TR><TR><TD CLASS="quote">I noticed that the inside of my tire has worn out and my tires stick out like crazy, they have an angle to it...what are the best camber kits to use? i need both front and rear and what brand</TD></TR></TABLE>
Did you lower your car and not get an alignment? Camber itself will not kill your tires unless it's crazy, toe will though.
Old Mar 1, 2006 | 05:42 PM
SIRIUS EJ8's Avatar
My car had the same problem..i thought it was because the custom springs..so i went and got my 96 civic put to near stock height..I used struts and spring from a 95 civic sedan...worked fine..but the wheels still stuck out...bad crooked...so a month later after i really bugged me i was loosing tires every two weeks...literally...burning off tread from the inside..so i took it to get aligned about a month ago..and the guy tugged the wheel and was like it's not the alignment..the alignment aint gonna help...so it had to be the camber..I was going with some Skunk 2 cambers front and rear..but my car didn't last that long..get those cambers man..you're civic will love u for it..
Old Mar 2, 2006 | 10:52 AM
defkid999's Avatar
alright, ill probably end up getting skunk2 front and rear camber kit
Old Mar 2, 2006 | 12:55 PM
slowpokecivic's Avatar
Default Re: (defkid999)
what kind of car do you have? you technically dont need the rears...you can do the washer trick...depending on what you have...
Old Mar 2, 2006 | 12:57 PM
AutoXer's Avatar
Default Re: Camber Kit (SVOboy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SVOboy &raquo;</TD></TR><TR><TD CLASS="quote">
Did you lower your car and not get an alignment? Camber itself will not kill your tires unless it's crazy, toe will though.</TD></TR></TABLE>
I have crazy camber with even wear. You need to have the toe set to 0, which is more critical the more camber you have. Camber can accelerate toe (uneven, inside) wear, but doesn't cause it.
turbotime
Jul 24, 2006 06:41 AM
blk94gsr
Feb 11, 2006 07:23 PM
thegoods217
Suspension & Brakes
Mar 22, 2005 08:26 PM
underpressure02
17
Jun 21, 2004 12:53 PM
CivicSwapper
Dec 11, 2003 06:53 AM
