Tool for O2 sensor?
Old Mar 1, 2006 | 01:35 PM
shbrown's Avatar
Default Tool for O2 sensor?
I have read conflicting information condering this when I search. I have heard I need a 7/8" wrench, or a 22mm wrench, or an O2 sensor tool. I would prefer not to remove the fan, but if I have to I will. Can anyone confirm the tool needed?
Old Mar 1, 2006 | 01:38 PM
kulangot's Avatar
Default Re: Tool for O2 sensor? (shbrown)
i think the 02 sensor tool is the best..
Old Mar 1, 2006 | 01:39 PM
SETI20's Avatar
22mm wrench works...but the tool is your safest bet.
Andrew Marquis's Avatar
Go ahead and get the O2 sensor Socket and save some time.
Old Mar 1, 2006 | 01:56 PM
fireant's Avatar
The O2 sensor tool is ~$10 at most discount auto places or Harbor Freight tools. It makes removing the sensor much easier, because it is difficult to get a regular wrench so close to the manifold and still have room to turn it.
Old Mar 1, 2006 | 02:27 PM
hatchinprogress's Avatar
Default Re: Tool for O2 sensor? (fireant)
you can check out an o2 sensor for free at autozone (they charge $16 to your c.c. and refund it when you bring it back)
Old Mar 1, 2006 | 02:32 PM
Tyson's Avatar
7/8" = 22mm roughly.
the 02 sensor tool is only worth it if you are using an impact gun, or really need to use a cheater bar, which is used instead of a normal socket.
the issue is the sensor wire that prevents using a normal socket.
i prefer just using a 22mm box end wrench tho.
Old Mar 1, 2006 | 02:56 PM
shbrown's Avatar
Thanks guys. I think I'll start with buying the 22mm open ended box wrench, and if this is unsuccesful, rent/buy the actual tool.
Old Mar 1, 2006 | 02:58 PM
Tyson's Avatar
Default Re: (shbrown)
make sure it has a BOX end wrench, not just an OPEN ended crescent. usually its a "combo" at each end anyway.
ITRFreddy
Sep 6, 2017 02:34 AM
hydengr
Honda Civic (2001 - 2005)
May 27, 2015 10:02 AM
dohcvtecpower
May 7, 2009 07:41 PM
mickey513
Jun 2, 2002 04:42 PM
