engine reving to high
Old Mar 1, 2006 | 07:19 AM
jayz_si's Avatar
Default engine bogging out
89 d16a6 1.6 single cam non v-tec balanced crank and rods stock pistons and rings,shaved head,5 angle valve job,ported intake man,tb bullfrog butterfly,bullfrog stage 2 cam si ecu chipped rev limit at 7000rpm motor pulls damn hard AEM short ram intake 1st gen b16 injectors.
The motor is reving at 3000 rpm and the ecu is give me 3 codes 9,7, and 20. What can i do to fix the problem.
Modified by jayz_si at 1:28 PM 3/1/2006
Old Mar 1, 2006 | 12:31 PM
jayz_si's Avatar
I switched TPS and the Map sensor plugs, the cars idieling fine tried takin it for a ride the motor almost dies out. Check codes on the ecu its giving me 3 and 9 im lost. What to do?
Old Mar 1, 2006 | 12:35 PM
d16efsedan's Avatar
Default Re: (jayz_si)
i'll take it easy since your a newb...https://honda-tech.com/zerothread?id=468260 search and also the faq section has alot of good info .hope that helps some
Old Mar 6, 2006 | 08:32 PM
jayz_si's Avatar
what would happen if the tps sensor wires werent switched going into the sensor on the throttle body . What problem would that cause?
Old Mar 6, 2006 | 11:48 PM
manyakiexpi's Avatar
try adjusting the tps because i took mines off on my old crx and when we put it on it was making my car rev at 3000rpms also and than we readjusted it and it reved at 2500rpms and than i took it to a shop and the guy put it back how its suppose to and it idled back down around 1000 so check that or clean our you iacv
Old Mar 7, 2006 | 06:34 AM
jayz_si's Avatar
I will give it a try and see what happens.
Old Mar 7, 2006 | 11:21 AM
jayz_si's Avatar
How do you adjust the TPS? When the car is cold it idles fine but when it warms up it dies out and wont start.
Old Mar 7, 2006 | 12:28 PM
HmMm...that sounds weired. usually it would be that when its cold it would be idling high and when its warm it idles fine. maybe if its dying out when its warm and wont start its maybe over heating? thats how my friends car was. it would idle high though when its cold and when it warms up it turns off n wont start till its cold again due to over heating. try to replace your thermostat.
Old Mar 7, 2006 | 01:53 PM
jayz_si's Avatar
Got the car starting ecu is reading code9 and its reving at 3000rpm.
Old Mar 7, 2006 | 02:58 PM
hMmM....not really familiar with all the codes
Old Mar 7, 2006 | 03:12 PM
Steri's Avatar
did you check the link posted above? Here it is again.
it has great trouble shooting flow charts and such.
Old Mar 7, 2006 | 03:48 PM
jayz_si's Avatar
the cars running good now but the fan wont turn. Could it be the thermestat
Old Mar 7, 2006 | 04:06 PM
si0385.'s Avatar
how hot is it? could be the relay
Old Mar 8, 2006 | 03:36 AM
jayz_si's Avatar
hot when i went to check the temp gauge it was up at the red almost.
Old Mar 8, 2006 | 06:11 AM
C_R_X_V_T_E_C's Avatar
Replace The Thermostat, its cheap, its easy, and Hey YA never know, it might just solve your problem, BTW: Code 9 is No. 1 Cylinder Position (Cyl Sensor).
Gavin G
20
Aug 2, 2014 05:25 AM
davidgt
Mar 14, 2014 10:05 PM
trippsEF9
Apr 3, 2013 11:08 AM
chope045
12
Dec 12, 2010 06:36 AM
pmachan
Sep 7, 2005 08:18 PM
