97 1.5 sohc vtec wont rev past 3k rpm.??
hi guys my civic wont rev over 3k rpm am pure confussed :/ ive changed the dizzy and the tps sensor and the maf sensor and ive tried changing the ecu and still have the problem.?? and i have no engine light on :/ any help would be great.? thanks in advance...
Re: 97 1.5 sohc vtec wont rev past 3k rpm.??
Check your tps sensor if you screwed it in, because it can be too far left or right. There is a way you can test it to the right specs with a multimeter. look it up on HT.
Another thing you should also check it your timing, it could be too advanced.
Also is it redlining at 3k or bogging out?
yea i was thinking the timing might be off am going to try that tomorrow,its bogging down at 3k :/ sorry i ment map sensor on top of the intake mani,,its a 1.5 v-tec e d15z6 civic and the ecu is 37820-p2y-G01,,i put in a diff ecu off a 1.5 vtec and the engine light came on and gave the code for the tps sensor so i changed it and the light went off but its still bogging down at 3k rpm :/
hey guys went i start the car now it rev's up to 1k rpm and then just die's off and stops :/ but if i pull one plug up the car will run on 3 cylinders and even on 2 but went i put the 4 plugs in it just starts up and die's down and cuts out,,would dis mean the timing is off.? and would it throw a code if the timing was off.? my head is wrecked i changed the dizzy,tps,map sensor and the ecu,,all i can think of now is the timing.? any help would be great thank you..
haa i mean as it has me pure confused tryin to figure out the problem tryed the timing and that seems to be perfect,,would it throw a code if there was a problem with the timing.? all i can think of now is a fuel problem maybe a injector has packed in.? :/ the car starts up now and just dies of straight away as if it isnt geting any fuel.??
I never narc'd on nobody!
Seems to be perfect, or is perfect? Post pictures of the crank and cam at TDC. While you're doing that, do a compression test. You can buy/borrow/rent the necessary tool from your local parts store. While you're there, you should also buy a HEI spark tester (they're cheap), and a fuel pressure tester. After you've posted those pictures, we can walk through how to use each tool to get some real diagnostics done.
TheIceMan
12
12-23-2005 04:08 AM
