Timing Belt Issues
Old Mar 1, 2006 | 05:19 AM
Scorchin Civic's Avatar
Default Timing Belt Issues
Ok, here is my problem! I changed my water pump that was on my B20Z2 with a 99 GSR pump. I also bought a GSR timing belt. I can't seam to get the timing belt to tighten up. I have an all motor non-vetc setup. Should I have used the same B20 belt? This is what I think the problem is however, I would like to see what someone else has to say.
Old Mar 1, 2006 | 07:30 AM
.xcalibur.'s Avatar
Why didnt you use b20 parts in the first place? Maybe the timing belt is shorter on the b20? are you is the tensioner pulley already maxed out?
Old Mar 1, 2006 | 08:58 AM
I wanted a little better water pump since the original one was no good. That's why I bought a GSR one. I was also told to go with the same type of timing belt as well.
Old Mar 1, 2006 | 03:52 PM
NJIN BUILDR's Avatar
Default Re: (Scorchin Civic)
The gsr water pump isn't "better" than a b20 or ls pump.It has more teeth so that the pump turns slower at high rpm.Not necessarily the best thing on a lower reving non-vtec engine.The gsr belt should be the right one for your setup.
Glenn
Old Mar 1, 2006 | 04:49 PM
Default Re: (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">The gsr water pump isn't "better" than a b20 or ls pump.It has more teeth so that the pump turns slower at high rpm.Not necessarily the best thing on a lower reving non-vtec engine.The gsr belt should be the right one for your setup.
Glenn</TD></TR></TABLE>Well, that's something I didn't know if that's a true statement. Not that I am saying it's not, it's just that I never heard that before. So, will this pump cause a problem?
Old Mar 1, 2006 | 04:53 PM
UPDATE: After missing around with it a little and using a coat hanger to help pull the tensioner up I got it to tighten really good. Drove it around for about thirty min. and checked it, still the same as when I tighten it. So I guess that spring must be worn.
Old Mar 1, 2006 | 05:25 PM
https://honda-tech.com/zerothread?id=733657
Just one of many....
Kirk@SyndromeAuto
25
Oct 9, 2015 08:03 PM
ekturbohatch22
May 11, 2007 07:25 PM
1SickHb
Oct 4, 2005 09:00 AM
erebunicrx
Feb 20, 2005 08:31 AM
dElSleepiE
Jun 1, 2003 08:56 PM
