What kind of common engine builds for a 95 Dx 5spd
Old Mar 1, 2006 | 05:01 AM
TheCollectiveFoundation's Avatar
Default What kind of common engine builds for a 95 Dx 5spd
Just trying to get a idea of what other people are doing out there on the dx's?
Old Mar 1, 2006 | 05:03 AM
G2 Speed's Avatar
Default Re: What kind of common engine builds for a 95 Dx 5spd (TheCollectiveFoundation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCollectiveFoundation &raquo;</TD></TR><TR><TD CLASS="quote">Just trying to get a idea of what other people are doing out there on the dx's?</TD></TR></TABLE>
sry man that question is super super vague......
that could range from a drop-in K&N filter, to a greddy turbo kit...
Old Mar 1, 2006 | 05:08 AM
I mean what are common ways to get the car to 170-200 with out spending buck wild money
Old Mar 1, 2006 | 05:10 AM
G2 Speed's Avatar
Default Re: (TheCollectiveFoundation)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCollectiveFoundation &raquo;</TD></TR><TR><TD CLASS="quote">I mean what are common ways to get the car to 170-200 with out spending buck wild money</TD></TR></TABLE>
homemade turbo
search for it
Old Mar 1, 2006 | 05:19 AM
I just want to go NA only because I want this engine to last some time.
Old Mar 1, 2006 | 05:26 AM
G2 Speed's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TheCollectiveFoundation &raquo;</TD></TR><TR><TD CLASS="quote">I just want to go NA only because I want this engine to last some time.</TD></TR></TABLE>
well then your gonna have to probably spend more money the you expected... to get 170-200, a mini-me swap along with some mods.... i/h/e.. can get you closer to your goal
Old Mar 1, 2006 | 05:30 AM
No can you tell me this, is it hard to do a mini-me swap yourself and which one is better the z6 or the y8
Old Mar 1, 2006 | 05:35 AM
Slow EJ8's Avatar
I dont think you will get to 170-200whp N/A without spending some serious money. Your best bet is to do a turbo setup yourself and get it tuned very well. A good tune will make it decently reliable.
Old Mar 1, 2006 | 08:28 AM
Everyones Hero's Avatar
Default Re: (Slow EJ8)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Slow EJ8 &raquo;</TD></TR><TR><TD CLASS="quote">I dont think you will get to 170-200whp N/A without spending some serious money. Your best bet is to do a turbo setup yourself and get it tuned very well. A good tune will make it decently reliable. </TD></TR></TABLE>
A good tune will make it very reliable.
I'm running my semi-tuned car w/ 10psi on a small turbo. I'm making around what your power goals are, if not a little more. Put some effort into searching about crome (www.pgmfi.org). I found crome difficult to start with, but as I do more research and play with it more it becomes easier to use.
If you're not into self-tuning you could look at the Tuner Directory in the FI forum and find a tuner in your area.
People don't realize how reliable turbo setups can be if they're put together properly, tuned well and taken care of. We've come a long way since VAFC/SAFCs and MAP hacks.
edit: If you're looking to doing a mini-me I would reccomend just doing a complete Z6/Y8 swap. I believe it was Bauley Civic that did the original mini-me writeup, and then did a followup as to why you shouldn't do a mini-me.
Old Mar 1, 2006 | 10:59 AM
robert_v's Avatar
if you are going n/a, go b-series swap. only way you can reach 170+ hp without spending alot of money.
Old Mar 1, 2006 | 11:25 AM
mwieczorek43's Avatar
Default Re: (robert_v)
try http://www.turbod16.com and http://www.homemadeturbo.com.
You can piece together a reliable junkyard kit for around $500-$800. Turbo is the only way you'll make those numbers on that engine.
surfmanvabeach
10
Sep 6, 2007 06:06 PM
1234567899876543211230
10
Oct 3, 2006 11:44 AM
ssr_h22
Mar 28, 2005 10:17 PM
trigga
Nov 2, 2003 09:27 PM
