doing some wire tuck, need help with removing stuffs.
What is that tube for? I removed the huge black can from the car when i converted to obd1, my map is on the TB now. Do i need to connect something there or can i leave it just like that?
Another thing, i removed the entire harness that goes to the ac ( i will run the radiator fan directly ) Any problems with this?
I also removed the black canister where most vacuums used to go when i was obd0, plus i also removed the purge valves. I will post pics of the stuff removed so you guys can tell me if I need them back.
Its the vapor return line that was what the charcoal canister (the black thing) was hooked to its for emissions.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beau Gotti »</TD></TR><TR><TD CLASS="quote">are those ABS lines?
i dont think my rex has all that mess ther eunder the fuse box</TD></TR></TABLE>
nope standard lines going into the prop. valve. 2 in and 4 out
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Beau Gotti »</TD></TR><TR><TD CLASS="quote">probally ran the harness through the center main harness hole i would thunk</TD></TR></TABLE> thats what I did on the main harness and the eng harness
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boosted Chemist »</TD></TR><TR><TD CLASS="quote">thats the gas tank purge, just leave it open, so fume can vent. That is how mine is routed</TD></TR></TABLE>
You can do that, but its safer if u get some 1/4inch hose and run it like this...the end is where the bottom hose of the charcoal canister went before u removed it.
Its cleaner too, heres mine
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SETI20 »</TD></TR><TR><TD CLASS="quote">Looking good so far.
Get rid of the plug on the wiper motor too, and paint that thing black.</TD></TR></TABLE>
Thats not his car, thats Vince's of ATS. RIP
the.hamburglar
10
Jun 14, 2007 10:17 PM
coupedragracing
Sep 5, 2006 02:52 PM
