Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Sway bar and camber kit
Old Feb 28, 2006 | 10:06 AM
rockdude14's Avatar
Default Sway bar and camber kit
ok spring break is coming up so thats when ill change most of the stuff so if anything breaks ill have time to fix it. This is for sts in solo2
anybody have any recomendations on which camber kits to get for the front and back
with the new springs (600/600) it has about -.5 degrees on all wheels
i also plan on adding a rear sway bar not sure what kind
with the springs it seemed to handle pretty neutral so i want a little more oversteer
This is on a 01 integra gsr
koni yellows
600f/600r GC
Old Feb 28, 2006 | 01:06 PM
GChambers's Avatar
Default Re: Sway bar and camber kit (rockdude14)
You may gain enough camber just by lowering the car. If you are trying to get rid of the rear camber, see if the bolt and washer trick works for your car like it does the Civics.
Old Feb 28, 2006 | 04:34 PM
rockdude14's Avatar
well the -.5 was with the drop
plus id like it adjustable so i can find what works best with the rest of the setup
Old Mar 2, 2006 | 09:53 AM
rockdude14's Avatar
Default Re: (rockdude14)
i find it hard to believe that no one hear has any experience with sway bars or camber kits?
Old Mar 2, 2006 | 11:00 AM
solo-x's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockdude14 &raquo;</TD></TR><TR><TD CLASS="quote">i find it hard to believe that no one hear has any experience with sway bars or camber kits?</TD></TR></TABLE>
Someone should bE Able to wRite a Couple Haikus on searching for you....
nate
Old Mar 2, 2006 | 11:17 AM
chjkingme's Avatar
Default Re: (solo-x)
Oh, goodie...haikus
formula behind
will i get my shocks on time
deadlines F T W
we have no sway bars
or camber kits- don't need em
quit racing hondas
wait, this is not helpful..
a freight train derailed
i'm bored, but have work to do
red font, upper right
haikus, like pringles
i must be sick in the head
time to go now :waves:
where's matt
Old Mar 2, 2006 | 11:32 AM
rockdude14's Avatar
i did search i found nothing in regards to sway bars and racing lots of just random comments on sway bars with nothing to back it up
and on camber kits its mainly i dropped my car what camber kit should i get so i dont kill my tires
if you found somthing relivant please post it
Old Mar 2, 2006 | 11:40 AM
chjkingme's Avatar
bars all work the same
check rules for reinforcement
testing is the key
camber? go lower
if you don't want to then you
don't need every tenth
half a degree wont
hurt your tires without toe
keep on searching Now!
Old Mar 2, 2006 | 11:49 AM
rockdude14's Avatar
oh i didnt mean i care about my tires i meant that most posts on camber kits in the suspension forum are about that
rules for reinforcment have changed to this
14.7 ANTI-SWAY BARS
Substitution, addition, or removal of any anti-roll bar(s) is
permitted. Bushing material, method of attachment, and locating
points are unrestricted. Components such as anti-roll bars and strut
housings that serve dual purposes by also functioning as
suspension locators may not be modified in ways that change the
suspension geometry or steering geometry. Non-standard lateral
members which connect between the brackets for the bar are not permitted.
so for camber i should just lower it to how ever much camber i want and skip the camber kits
Old Mar 2, 2006 | 11:56 AM
chjkingme's Avatar
Well, don't go so low that you're bottoming out your shocks, but most people seem to be able to get the camber they need without the kits.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rockdude14 &raquo;</TD></TR><TR><TD CLASS="quote"> Non-standard lateral
there's a thread here somewhere on the legality of these, but someone else will have to find it. I'm lazy when I can't write poems.
Old Mar 2, 2006 | 12:01 PM
rockdude14's Avatar
http://sccaforums.com/forums/thread/162172.aspx
this is the thread i was referring to
the major problem i see is that it basically makes anything like the comptech or ASR brace illegal
Old Mar 2, 2006 | 12:26 PM
chjkingme's Avatar
I use the Beaks pieces on the same chassis without problems and at lower spring rates than yours.
jaygood2go
May 23, 2013 01:43 PM
shotgun2224
Suspension & Brakes
Nov 3, 2007 02:25 PM
ThrashSM
Jul 20, 2004 10:58 AM
KTeller8
Aug 26, 2002 05:04 AM
00civicsimobstyle
Aug 6, 2002 10:57 AM
